LQ9 Injectors
Old 11-10-2007, 08:32 AM
blazin's Avatar
Default LQ9 Injectors
Whats the flow rate on these? My buddy has the whole intake off the 6.0 he wants to get rid of. Would I benifit from swapping it out? I know a tune would be needed.
Old 11-10-2007, 08:41 AM
sbw9056's Avatar
Thier flow rate is 26lb an hour. The 6.0 manifold and injectors are the same as the 5.3 and 4.8.
Old 11-10-2007, 08:43 AM
PT's Slowest Truck
budhayes3's Avatar
They are 24.7lb, same as the 4.8-5.3's. 00 and up 4.8-6.0's are all 24.7lb, while 99 is less (21lb I think?). If you're referring to the 99 truck in your sig, and you plan on future mods (cam), then you will benenfit from the larger injectors, but your PCM must be tuned to accomodate them or you'll run pig rich.
malibudave (05-03-2023)
Old 11-10-2007, 09:03 AM
slowprocess's Avatar
I personally wouldn't make the swap for anything less than the stock 8.1L injectors.....you can usually pick up a set for under $100 if you look around.
Old 11-10-2007, 10:17 AM
blazin's Avatar
Im not going to do a cam gonna run a low boost turbo, I have been looking around for some 8.1 injectors but no luck so far.
OHsixLS3
09-25-2015 11:20 AM
Pontiac Derek
09-19-2015 01:49 PM
Justin87gn
09-10-2015 12:06 PM
CammedZ71
11
09-09-2015 02:05 PM
lxcoupe
09-02-2015 12:58 AM
Quick Reply: LQ9 Injectors
