LQ9 Injectors
LQ9 Injectors
Whats the flow rate on these? My buddy has the whole intake off the 6.0 he wants to get rid of. Would I benifit from swapping it out? I know a tune would be needed.
PT's Slowest Truck
They are 24.7lb, same as the 4.8-5.3's. 00 and up 4.8-6.0's are all 24.7lb, while 99 is less (21lb I think?). If you're referring to the 99 truck in your sig, and you plan on future mods (cam), then you will benenfit from the larger injectors, but your PCM must be tuned to accomodate them or you'll run pig rich.
malibudave (05-03-2023)
Pontiac Derek
09-19-2015 01:49 PM
