LQ9 head gasket leak
Old May 29, 2019 | 09:10 PM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by firebladeJJ
Would anyone care to guess why my truck is now killing the battery ? Brand new got it Saturday. It started yesterday fine. I cleaned the main negative cable connection on the block. Where are the other grounds at?
Does it have an Aftermarket Stereo or Alarm?
If so, Disconnect those first and see if it's the killer...
Old May 29, 2019 | 10:30 PM
  #22
firebladeJJ's Avatar
It has an aftermarket radio but its sat for months before and never been been that dead, there was nothing....not event a flicker of power when I opened the door.. the door lights usually come on even if theres not enough power to start the truck, this had squat. when i hooked up my charger to the battery it said 0.0 volts. never seen a battery that dead.
I did notice they painted the block with something, do you think the grounds on the back of the block not having a solid connection may have something to do with the rapid discharge of the battery?
Old May 30, 2019 | 06:11 PM
  #23
1FastBrick's Avatar
Paint on the block under the ground wires could cause a Voltage drop. It would not cause a drain but vould make it tough to charge properly. Either the battery is bad (Which is rare), or you have an electrical draw some where causeing it to drain it.
On my DD, it was the brake lamp switch that went bad. The brake lights where Stuck on and killed the battery.
On the Turbo Truck, its something with the aftermarket radio and speaker set up causeing a draw. Never even bothered to look. Just pulled the power wire and been like that ever since. Last owner Bricked 2 PCM's durring flash process and killed a battery because the battery would drain and never fully recover.
Old May 31, 2019 | 08:40 AM
  #24
It was in fact a bad battery. It failed a test in about 30 seconds with 2 bad cells.
Old Jun 1, 2019 | 12:04 AM
  #25
1FastBrick's Avatar
Cool!!! Glad it was that simple.
Relentless07Silv
May 5, 2014 03:40 PM
shakinlm7
Jan 19, 2011 01:28 PM
getchusum99
May 10, 2010 04:08 PM
mushroom281
Apr 22, 2010 05:05 PM
Seeing Red Again
Mar 6, 2006 06:19 PM
