lQ4 part two....
Old Apr 1, 2012 | 07:22 PM
  #21
Team Paulie's Avatar
Registered User
Tell me about it,oh well, guess GM was using those heads on other engines and not just the LS-2's.
Old Apr 2, 2012 | 10:29 AM
  #22
Registered User
Dropped some cash off Saturday for my total bill, Anybody got a part number for the steam vent cap gaskets? Also this engine was in a 4X4 chassis and my 2wd didnt have a external oil cooler,I really wanna reuse the oil cooler system but does any one know which line is inbound and which line is outbound?
Old Apr 5, 2012 | 10:26 AM
  #23
Registered User
UPDATE...
Stopped over and saw my motor as it was torn down, gonna need a crank cut,looks like this thing sat outside for a period of time and had a swimming pool in the oil pan.
Old Apr 5, 2012 | 03:55 PM
  #24
Beatdown Z's Avatar
Laid Back
You can find the steam vent tube gaskets for cheap on rockauto.
Old Apr 5, 2012 | 03:58 PM
  #25
Registered User
get to have my crank cut down too.
Old Apr 5, 2012 | 04:02 PM
  #26
Registered User
I should be able to find them, all I do is look up parts all day,any idea were they might hide em? Heads? evap system?
Old Apr 6, 2012 | 04:07 PM
  #27
Beatdown Z's Avatar
Laid Back
Click on "Cooing System", then choose "Coolant Water By-Pass Gasket"
Old Apr 6, 2012 | 06:35 PM
  #28
01silvy's Avatar
Sucks about your crank man, atleast it will be right when its done.. keep us updated
Old Apr 7, 2012 | 09:40 AM
  #29
Registered User
Stopped by again and saw it,the back two cylinders,7 and 8 must have been siting in water,the bearings were not too bad but did need some work along with the crank in that area,all the others forwards looked brand new,pistons looked good,none of the coating on the sides was worn or even touched,little heavy on the carbon build up but that was flaking off and will come off in the tank.
I am gonna have about 1400 in tear down,bearings,clean up,build up,degree the cam and a full set of ARP hardware.
Old Apr 9, 2012 | 09:16 AM
  #30
Registered User
As far as the sensors and stuff, Do I swap over from the 4.8 or use the 6.0 stuff?
