lQ4 part two....
Old May 30, 2012 | 10:42 AM
  #31
Team Paulie's Avatar
Registered User
Back from the dead.....
Get to bring her home on friday,
Run down of all what was done
1.-Complete tear down to bare block
2-sonic and X-ray block
3-Block cleaned and blasted
4-Honed
5-Ressambley
6-Stock pistons with O.E.M rings
7-Two new rods and all new pins and clip
8-Stock crank was cut .010's with bearings
9-Line honed
10-Stock 317 heads milled .020's,with bronze springs,five angle valve job,mild port and clean up.
11-new freeze plugs
12-Comp cam 228R with 588 lift and 110LSA
13-texas speed 7.4 push rods
14-O.E.M gasket kit from pan to valve covers
15-new knock sensors and harness
16-reassembly
17-crate to get it home
18-painted block black heads and covers are natural.
I think there is more but thats all I can remember till the bill is in front of me,I hope this thing is a power house and lasts another 100,000 miles....
Old Jun 22, 2012 | 08:49 AM
  #32
Registered User
Anybody making 500 hp or more with stock pistons?
Old Jul 18, 2012 | 08:16 PM
  #33
2doorfury's Avatar
500hp with stock pistons shouldnt be hard at all when theres 700+hp guys with stock pistons..
Old Jul 18, 2012 | 08:34 PM
  #34
KMAN99's Avatar
My setup is in my sig, but for what it's worth on a mustang dyno it put down 366hp/402ft. lb. on a 100 degree day.
Old Jul 18, 2012 | 08:42 PM
  #35
2doorfury's Avatar
what gears you running KMAN?? 12.89 seems low for that setup..ive seen simular setups run 12.5's...
Old Jul 18, 2012 | 08:51 PM
  #36
KMAN99's Avatar
3.73 gear. 26x11.50x16 tire. well like it says personal best. It doesn't run that consistently. The night I ran that time I'd say it was about 60 degrees outside. Normally on a 85 degree night it runs 13.1 -13.3 pretty consistent.
Old Jul 19, 2012 | 09:52 AM
  #37
Registered User
Sounds really close to what I have but not the injectors,I already had the long tubes, my engine was a 2004 LQ4 not a LQ9,but we did mill the heads and he did a very good port job,as far as the other mods you got I have just about the same,Efans,same gears,I also have a 150 shot to put on top of it too.
Old Aug 22, 2012 | 02:39 PM
  #38
Registered User
Bit of a update,old engine is out and all is swapped over,just doing some clean up work under the hood and painting some things,waiting for some parts to come back from the powder coat,slow and steady I'm getting it done,with out a extra set of hands I never wold have gotten this far,
Block was basically seized to the trans,but after some PB blaster and a big *** pry bar we got it,soon as the other engine is in and the converter is hooked back up I can take back over and finish it off,maybe this week I can be up and running.
Old Oct 9, 2012 | 10:16 AM
  #39
Registered User
As I said,she runs......
Old Oct 9, 2012 | 10:40 AM
  #40
03sierraslt's Avatar
We want videos.
