LQ4 crank bolt
Old Oct 29, 2012 | 04:04 PM
Team Paulie's Avatar
Registered User
Default LQ4 crank bolt
What is the specs and how do I put it back in?
I know you use the old bolt to start it and then the new one,loctite it in?
Is it a TQ to yield bolt?
Got a new one for 4.00 bucks and the old one kept backing out even after tightening and angling it,have yet to go full throttle cause of it,guessing the threads should be clean and no grease on them too right?
2004 LQ4 6.0 stock crank balancer and bolt.
Specs anyone? or a how too?
Old Oct 29, 2012 | 10:10 PM
CashDudeHomie's Avatar
240 lb with old bolt. Then 37 lb and +140 degrees with new bolt. These are the official GM specs. Yes it is TTY and has some kind of orange adhesion aid so it might back out if you try to reuse it.
I never got to 240 btw. My wrench doesn't even go that high. I just used a big @$$ pipe.
Old Oct 29, 2012 | 10:18 PM
dirt track racer 81's Avatar
air gun.. never fails..
Old Oct 29, 2012 | 10:24 PM
TDFDiesel's Avatar
Until it does.
Old Oct 29, 2012 | 10:40 PM
Originally Posted by TDFDiesel
Until it does.
shitty air gun... My bolt is my original 5.3 bolt and has been in and out 20+ times and always used an air gun.. done 20+ cam swaps on other vehicles.. no problem..
Old Oct 30, 2012 | 08:31 AM
Registered User
240ft lbs!!jebus....Gotta wait till the weather calms down around here do I can do this again,should I put some red loctite on the threads?
Old Oct 30, 2012 | 10:05 AM
SuperStepside's Avatar
Or get an arp crank bolt. Its just a regular bolt so you can re-use it. Dont have to worry about getting the torque angle right.
Old Oct 30, 2012 | 10:34 PM
There's no need for thread lock if you use a new bolt. I've never had one back out and
I've been through probably 5 bolts because of cam and oil pump swaps.
Old Oct 30, 2012 | 10:42 PM
dmelvin's Avatar
If you want to use loc-tite, I would not use red... It would take a long time to heat the bolt up enough to break the bond of red.
Old Oct 31, 2012 | 12:06 AM
Ferocity02's Avatar
I used an ARP bolt and just tightened it by hand as much as I can with an 18" breaker bar.
