LQ4 cam and stall.....which one?
Old Jul 31, 2006 | 04:52 PM
HvyChevyZ71's Avatar
Default LQ4 cam and stall.....which one?
I think to make truck move like I want, Im gonna need to cam it and put in a stall to get off line hard. I will stay N/A for a while so I dont need a blower cam, I just want something that is good for daily driving but give me the most power. I really want more tq, to get off the line, thats definetely the slow spot on this truck. I know its a 2500HD but I believe the 6.0 is capable of pushing it pretty fast. Please let me know what yall recommend and any experience you might have. I will buy the 918 springs if needed and probally have to go with another mail order tune since there is no one around me that can dyno tune. What kind of gains could i see with these mods and my supporting bolt on's. Thanks for any help.
Old Jul 31, 2006 | 05:12 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
First decide on how much stall you can live with for your daily driver, and then an cam to match. Do you plan on tow or hauling?
Old Jul 31, 2006 | 05:14 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Stock HD stall is 2500 correct? A nice cam would be the venerable 212/218 comp grind for what oyu are looking for.
Old Jul 31, 2006 | 05:50 PM
im not really sure what I need that is why I need yall's help. Im new to stall converters and cam's, Ive always done the bolt ons but thats it, now I want to go to the next level. Can you tell me how my truck would react to that cam or something bigger/smaller? I tow about a maximum of 5000lbs rarely so towing isnt a big deal but I still want to be able to do it. I just want to go alot faster and have a good daily driver w/ decent gas mileage although I already get 10-11mpg so im not to concerned.
Old Jul 31, 2006 | 06:06 PM
dirt track racer 81's Avatar
ive put a comp 212 218 .522 .529 lift cam in a 6.0 2500 and it ran pretty for what it was..made power to 5600 rpm though..dunno what rpm you wanna run
Old Jul 31, 2006 | 07:18 PM
1slow01Z71's Avatar
I would keep the stock stall and build around that
Old Jul 31, 2006 | 07:24 PM
if i keep the stock stall, can i get a cam that will give me more low end to launch harder but still make power to 5800 rpm or so. I want more power throughout the rpm band but an emphasis on the low end. If i get a cam that helps low end, can it still make power in the higher end as well? Will a came make noticeable gain on this engine, especially with a retune?
Old Jul 31, 2006 | 07:29 PM
1slow01Z71's Avatar
Definately a seat of the pants difference even with a this small cam.
Old Jul 31, 2006 | 09:07 PM
ap2002's Avatar
maybe you can custom grind a cam, something like a 212/218 .590/.590 112lsa?? should be good??
Old Jul 31, 2006 | 10:12 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I have a 210/218 .551 .551 112lsa cam in my 5600lb Tahoe. It will jump off the line with a tap off the pedal and spin the 24's if I stab it. I have a 2600 stall. Pulls to 6000rpm on the dyno.
