LQ4 2500HD Towing Cam
#44
#46
heres a link to said article. the torque curve on test o looks like a good choice for towing, the cam seems very similar to the vinci 043, which isn't far from the 080. i wonder how much of a difference not having the l92 heads and intake will make.
6.0L Hop-Up, Part II - Speed Parts Testing
#49
I'd just replace the valve seals anyway. You are in there, they are cheap and will guarantee another 200,000+ miles before they start leaking.
If the heads are still on the engine, in the truck. Most put some rope in through the spark plug hole to fill in the empty space, so you don't drop the valve too low.
#50
Lingenfelter dual spring tool . . .
. . . or whoever decided to copy it . . . Proform Parts 67605
Depending on what valve springs you get, the dual spring kit comes with new valve seals.
The stock valve seals can be replaced at the same time when the springs are swapped.
