LQ4 2500HD Towing Cam
#31
This has been VERY educational. Thanks to everyone! My question is: if starting with a new engine, would it be worth bumping up the static compression to gain more torque? I plan a custom tune after installing the engine, so that should compensate for the rediculis cylinder pressure at low RPM.
#32
#33
#34
So, If I have this correctly, If The lift is kept in tht low 500s and the duration doesn't get over the 218 @ .050 then a person should still have a truck that could be driven every day and tow when needed, with better performance. I hate to be a pain, but with a kid in college, and another one starting next year, I probably only have one shot at this.
I read ten times more than I post so I can learn from all of you that gotten your hands dirty, and your wallets empty! Better to learn from those that do, than to make some of the same mistakes. Thanks again to everyone that had a hand in this.
#35
#36
What springs and p rods did you get? And where at?
#37
That and a tune should make for a very fun DD truck without breaking too much LOL
#38
I had the 212/218 comp cam and loved it but the VHP cam will definitely suite your needs more. Being that your not changing much, a Hardened 7.400" pushrod and decent springs is all you'd need. If your talking about upping the compression then get a set of heads off of a newer GM truck (08+) w/the 4.8 or 5.3. The casting numbers on the heads that you would need are 243 or 799. Those and that cam, and you will love the crap out of your truck Good luck, hope you don't get bit to hard by the mod bug afterwards lol
#39
