LQ4 2500HD Towing Cam
Old Jan 11, 2013 | 11:50 AM
  #61
akcooper9's Avatar
Reading over the install steps, looks like I also need:
1) front cover gasket
2) front crank seal
3) new crank bolt
Else I think I have everything covered.
When swapping cams on the trucks, does the radiator have to come out or is there enough room with it still in the truck?
Old Jan 22, 2013 | 05:19 PM
  #62
lowburb's Avatar
So, did you get it swapped?
Old Jan 25, 2013 | 09:00 AM
  #63
akcooper9's Avatar
I've got everything but wont have time to install until the end of February.
Ill keep you all posted
Old Jan 25, 2013 | 09:23 AM
  #64
53bowtie's Avatar
I believe you do have to pull the radiator to have enough room to slide the cam out. I think you can leave the condenser though, or at least leave it hooked up and move it enough out of the way.
Old Jan 25, 2013 | 09:24 AM
  #65
akcooper9's Avatar
That really sucks...anyone else confirm the above?
Old Jan 25, 2013 | 11:46 AM
  #66
99 2500's Avatar
Yes, definitely have to remove radiator but is no big deal. Condensor stays in place
Old Jan 25, 2013 | 12:32 PM
  #67
53bowtie's Avatar
Good time to do 34" radiator and e-fans if you havent already.
Old Jan 25, 2013 | 12:48 PM
  #68
akcooper9's Avatar
Didnt the 2500HDs come with the 34in radiator?
Im not sure I trust the e-fan for towing 10K lbs
Old Jan 25, 2013 | 02:41 PM
  #69
axekick's Avatar
The radiator comes out very easily. The worst part is losing all the coolant. I used the hose off of a compression tester and pressurized the cylinder through the spark plug hole with a compressor to hold the valve up.
Old Jan 25, 2013 | 03:44 PM
  #70
AKlowriderZ71's Avatar
11 Second Hall Moniter
Which has to be drained anyways, because you will be removing the water pump.
