LPP's installed now having some problems
Old May 7, 2009 | 12:43 AM
black04's Avatar
Default LPP's installed now having some problems
I just installed my lpp long tubes and i took my truck for a quick run around the block. Everything was fine until after about 5 minutes.
I stopped at a stop sign and it started to idle really low, shake and felt like it was going to die. So i pulled over and turned it off. Waited about 3-4 minutes, started it back up and rushed home. Everything seemed fine until i went to pull into my driveway and it stalled. I turned it back on and everything seemed fine again. So far there is no check engine light. What could cause this?
The wires arent touching the headers but a few of the rubber boots are touching it slightly. Could that be causing it?
Old May 7, 2009 | 01:26 AM
03 BLACKOUTSSS's Avatar
Its hard to say without any codes. Just slowly and methodically go over every step you took during disassembly / reassembly process. It sounds like you forgot one simple connector (IAT, etc...). I would also pull and reseat all the plug wires, from the plug end as well as the coil end.
Good luck.
Old May 7, 2009 | 02:14 AM
Mangled03gmc's Avatar
Baltimore Whore
Also doing what 03 said, pull a wire off the batt and let it sit for a while then hook it back up.. The will reset the comp then it will learn all over again and might things better.. You shouldn't have any probs from a simple header install..
Old May 7, 2009 | 11:18 AM
black04's Avatar
I had the battery unhooked while i was doing the install so i dont think that would cause it. I will try again tho.
Also i unplugged that rear 02 sensors from the harness since there arent any holes for them in the y pipe. Could that be the problem as well?
Old May 7, 2009 | 11:21 AM
budhayes3's Avatar
PT's Slowest Truck
Unhooking the battery could cause it, it may just need to re-learn the idle. There's a procedure for the idle re-learn, which I can't remember, but I've found that just driving it hard under various conditions usually allows the PCM to do an idle re-learn.
Old May 7, 2009 | 11:32 AM
black04's Avatar
Is it alright if the rubber boot slightly touches the header? It idles fine when it first starts up. Just after driving for a few minutes it starts to run like ****.
Old May 7, 2009 | 05:04 PM
Lifted03Chevy's Avatar
fixed?
Old May 7, 2009 | 05:48 PM
black04's Avatar
Not yet. I just got home from work so I'm going to check the plugs and wires.
Old May 7, 2009 | 06:43 PM
KevinF56's Avatar
if the rubber boot is slightly touching the header, it is fine. they shouldn't melt or anything, and certainly won't be causing the problems you're having.
Old May 7, 2009 | 06:47 PM
okietech's Avatar
I agree with budhayes3 and the idle relearn. when I Had my battery out for a day the next 2-3 days it would only idle around 200-300 rpm and die in every parking lot I was in. Just drive it and it should fix itself in a few miles or so.
