LPP's installed now having some problems
Old May 8, 2009 | 01:14 PM
  #21
TX Tahoe Z71's Avatar
Originally Posted by black04
I'm gonna pick one up right away. $30 per side at the dealership.
PM sent
Old May 8, 2009 | 05:56 PM
  #22
black04's Avatar
This came out of my turn down
Old May 8, 2009 | 06:43 PM
  #23
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
i beleive with long tubes and the rear o2s not plugged in this causes the truck to run really rich which I beleive explains the black spot? Am I correct?
Old May 8, 2009 | 08:44 PM
  #24
black04's Avatar
Yes that is right. Anyways i found another problem today looking under the hood. Will have pics in a minute.
Old May 8, 2009 | 08:46 PM
  #25
black04's Avatar
How can i fix this?
Old May 8, 2009 | 08:48 PM
  #26
GMCtrk's Avatar
You need MSD wires, you can bend the boot.
Also you need a tune bad. Your truck is running pig rich, which is why is running like ****
Old May 8, 2009 | 08:50 PM
  #27
black04's Avatar
I wasnt referring to the wires. I was pointing out the steering shaft. Is it adjustable in any way. I'm not sure how i didnt notice it before.
Old May 8, 2009 | 08:51 PM
  #28
GMCtrk's Avatar
You're gonna have to dent the header and also account for thermal expansion and flexion at the motor mounts. That sucks
Old May 8, 2009 | 08:52 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
How can i fix this?
I had this problem with my Gibson shorties, I tried loosening the bolt for the shaft and adjusting it, but ultimately had to loosen the gear box (3 bolts IIRC?) and shift it so that the shaft would rotate on a tighter axis. After shifting the gear box I had to do an alignment though. I basically just loosened the gear box retaining bolts and it actually shifted itself into place.
Old May 8, 2009 | 08:54 PM
  #30
andrew383's Avatar
traveling mod
your getting rear o2codes cause there not hooked up...That being said when i put my llp's on it threw codes within a mile of driviing it and run just fine untuned.
i would go ahead and get the wires that GMCtrk talked about,i have them and they hit no where.Pm GMCtrk for more info.
