Lowering oil pressure
Old Nov 19, 2010 | 06:35 PM
brent1976's Avatar
11 Second Club
Default Lowering oil pressure
I think I have ruined the seals on my turbo, because I my oil pressure is too high. Do I have to take the oil pump out to change the spring, or can it be done with the pan off?
Old Nov 19, 2010 | 07:26 PM
budhayes3's Avatar
PT's Slowest Truck
You'll have to get the oil pump out and on the bench
Old Nov 19, 2010 | 07:46 PM
brent1976's Avatar
11 Second Club
Well that sucks. Can I get the lower pressure spring at the dealership, or the zone or where?
Old Nov 19, 2010 | 07:48 PM
budhayes3's Avatar
PT's Slowest Truck
Good question, not sure on that one...
Old Nov 20, 2010 | 12:55 AM
Parke10's Avatar
i thought you could buy a fitting that goes inline of the oil feed to lower it just to the turbo?
Old Nov 20, 2010 | 01:09 AM
mhotrodscooter's Avatar
X2 ^^^ think it's call a oil jet.
Edit:Oil inlet restrictor for T series 1/8" NPT. Oil inlet restrictor for all T3, T3/T4, T04, T72 etc. turbos (also larger ball bearing turbos such as GT4088R, GT4094R, GT4294R, GT4202R). Restrictor diameter of .065 hole size. Installed at the oil inlet on turbo to reduce max oil pressure going into the turbo to prevent oil leakage into end housings due to excessive pressure. Input is 1/8" NPT male and output is 1/8 NPT female.
Old Nov 20, 2010 | 01:11 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm with these guys. Pretty sure there's a restrictor to put into your oil feed line somehow.
Old Nov 20, 2010 | 08:56 AM
brent1976's Avatar
11 Second Club
Here's the thing I have one of those, it's just a nitrous jet nipple. I started out with none, after a month it would lightly smoke after driving hard, then after 2 months, it smoked pretty hard sometimes. Then I got the restrictor, I started with the biggest jet, then did it all over again, and went through all the jets.
I didn't want to go to far and starve the turbo of oil, but should have started with the smallest jet to begin with.
At wot my oil pressure gauge pegs at 80, and it idles at 60, once it gets warm, it idles at 50-55.
Old Nov 20, 2010 | 03:05 PM
fredkj3's Avatar
i think a pressure regulator with a guage so you can actually see and control the pressure would probably be the best...
Old Nov 20, 2010 | 03:20 PM
I'm no expert, but IMO that oil pressure is higher than I would want it. By about 20 psi across the board. I'd probably re-do the oil pump if I was in your situation.
