Low dyno numbers on the 383
Old Dec 27, 2004 | 08:09 PM
  #21
parish8's Avatar
single digit dreamer
check out these threads
https://ls1tech.com/forums/showthrea...light=knock+de
Old Dec 28, 2004 | 12:11 AM
  #22
Originally Posted by ktmrider
You know, one thing I totally forgot about was that I bought a "used" ASA timing assembly from eBay ( 2 dyno pulls of use ). I wonder if I used the wrong keyway ( it is keyed for +/- 3 degrees ) and am advancing the timing too much?!? That would explain the top end falloff and excellent low end torque, plus some of the KR at high rpm's. Coulda swore I used the center key but it was 1000P at the time and I was running from the oven to the crank snout after heating it up.
Too bad it will take a total teardown to verify. Maybe an excuse to swap the cam?!? A good excuse at that....
Jesus Christ! You spent all the time and money to build a great engine and you DIDN'T DEGREE THE CAM?! I feel for you, but you deserve what you got for not paying attention to the important details! Again, call on the deity, Jesus! That may not be the problem, but you DON'T KNOW! Pull it apart and see!
Old Dec 28, 2004 | 12:44 AM
  #23
damn!!! that sucks
rednekferlife101
32
Jan 8, 2016 10:42 PM
Greatdivider
Sep 9, 2015 09:52 AM
dselby25
Aug 24, 2015 07:26 PM
ss4chad
Aug 15, 2015 02:25 AM
Cowboy17
Jul 9, 2015 08:22 PM
