Low dyno numbers on the 383
Old Dec 25, 2004 | 10:10 PM
parish8's Avatar
single digit dreamer
if you droped your kr cells to 4deg and are seeing 4 deg of KR then you have knock that the pcm can't do anything about. i am not sure if i understood what you said but i think i understood that corectly. maxing the KR is a very bad thing.
Old Dec 25, 2004 | 10:20 PM
(Ken)-96GMC K1500 SC's Avatar
Originally Posted by ktmrider
I finally had a chance to dyno the 383 iron stroker in my signature. I was hoping to see 350/350 wheel hp/trq.
Final numbers were very disappointing. Torque was there, 365, but the HP was tops at 280. The dyno curves were very wavy thru the RPM band and you can feel the truck fall flat above 3500 rpm.
I have been tuning with the stock O2 narrow band charts. The dyno shop thinks it is running very rich, and the HPT shows 4000+ to have -5 to -7 cells. I thought this indicated a lean condition?!? I am also concerned that the head work I had done might also be to blame ( 6.0 valves, 3 angle, slight polish work ).
Anyway, any feedback is appreciated.
Why you want to run move valve pressure! Also valves made of tool steel H-11 or better quality like lunati ultra series are the best!
http://www.cranecams.com/?show=newsLetters&no=65
Ken
Old Dec 25, 2004 | 10:47 PM
greentahoe's Avatar
You know, one thing I totally forgot about was that I bought a "used" ASA timing assembly from eBay ( 2 dyno pulls of use ). I wonder if I used the wrong keyway ( it is keyed for +/- 3 degrees ) and am advancing the timing too much?!? That would explain the top end falloff and excellent low end torque, plus some of the KR at high rpm's. Coulda swore I used the center key but it was 1000P at the time and I was running from the oven to the crank snout after heating it up.
Too bad it will take a total teardown to verify. Maybe an excuse to swap the cam?!? A good excuse at that....
Check out Ranwalk's most recent posts about his setup. It ran fine, but made alot less power than it should have. Im going to go out on a limb and say that this could be at least some of your problem.
https://ls1tech.com/forums/showthread.php?t=251980
Old Dec 26, 2004 | 12:07 PM
ktmrider's Avatar
Sorry to be vague, Jim. I made a PE table correction of +3% to all the cells at 4000rpm and up. I was using the scanner retard field to determine if I made a proper correction based on the amount of retard ( thinking I was too lean up top and creating detonation/knock ). I now believe the fuel change to ethanol blend is responsible for the better retard values ( -8 to -4 ).
Looking at everything now, I am pig rich at all throttle positions above 40% with both O2 sensors maxed out at 900+ at 40% throttle at all RPM's. The advance table shows a similar situation, it has very low advance from 40% / 2500rpm with some WOT advance at -5.
Boy, it just goes to show how a little knowledge goes a very little way with the tuning software.
Thx greentahoe for the thread from Ranwalk. Good chance I am a little advanced on the cam but more likely I am just being stupid on the fuel tables. The dyno operator thought a rich fuel condition would cause the graphs he saw and the scanner supports this. I also just read that the truck ECU tends to run richer than the car programs. I just need to get a little more humble and ask for some help!
Old Dec 26, 2004 | 08:32 PM
N20GMC's Avatar
If it is not tuning thats causing its the cam is not in straight up which you have already said.
What kinda valvesprings do you have. Valve float on the dyno will look like eractic high and low spots in the power curve. Although since you have an LS6 cam (which is way to small), wouldnt need very much vlave spring pressure to run.
Old Dec 27, 2004 | 01:13 AM
parish8's Avatar
tuning could easily be the problem. too much fuel and too little timing is no good for power.
i just noticed this is on a 99 truck. i had teriable problem swith false knock on my 99 and was probably a full sec slow because of it. i got to get to bed now but will post up a little more on that tomorrow.
Old Dec 27, 2004 | 10:43 AM
hey parish, did the '00 chevys have the same prob as the 99's, just curious since i read something a while back about switching the pcm's out to '02 model pcms. thanks
Old Dec 27, 2004 | 03:26 PM
ktmrider's Avatar
I am running the "blue" LS6 valvesprings, applicable to the 01 Z06 cam, so it should be OK. The dyno graph did not look like a valve float signature but I will look again once they email me the graph after the holidays.
Thanks for the follow up Jim/Parish, I welcome any suggestions.
I am thinking that even with some good tuning I may not see more than 30-40 hp increase with the Z06 cam. Most everyone agrees, the cam is WAY too small for the engine.
OK, now that the general consensus is in, how bout some cam suggestions? Some background info, we are emission tested every year here. The truck is 4wd ECSB and a daily driver. It will go to the track maybe once a year and mostly carry around dirt bikes. Anything that will provide good low end torque ( even with the stroker cubes ) and an occasional dyno/track pull is the best option.
Again, can't thank you all enough for the help and diagnostics!
Old Dec 27, 2004 | 06:17 PM
parish8's Avatar
i think it was just the 99's that had the false knock problem, not sure if you can just swap it out or not.
Old Dec 27, 2004 | 07:57 PM
ktmrider's Avatar
Was it ECU related or bad sensors that year? I can probably swap out the ECU as I have a good relationship with the local "auto recycler" ( gotta use that term or they get angry ). Down side is that the HPT will not like any of the other model year stuff, or so I believe.
I tried to have a 6.0L ECU map programmed in before getting the HPT but no one was willing to do it. Now I am realizing how little I understand about the HPT, time to start posting on their website for help.
