Looks like I lost #7 piston
Old May 11, 2008 | 04:19 PM
64CAMINO's Avatar
Originally Posted by kbracing96
It's our new room mate!! He was in my truck when it first pushed coolant, and he was also in Chris's truck when it when south! lol!!! J/k mike
Yes, I chanted a hex on both of them becouse they WERE both faster than me
Old May 11, 2008 | 04:22 PM
ZO6Ted's Avatar
I am really sorry to hear this thunder...tragic.
Old May 11, 2008 | 04:47 PM
ZZebes's Avatar
**** man, that suck
Old May 11, 2008 | 04:59 PM
2004SSS's Avatar
what intake are you running?
Old May 11, 2008 | 05:08 PM
ZZebes's Avatar
he's running an SSR 90mm
Old May 11, 2008 | 05:16 PM
00Silv4.8's Avatar
Dam Chris, so much for the hopes of a simple turned rocker or somethin huh? Sorry to hear it man. I hope he looks over the whole right side real good as well cuz those plugs looked almost like they were cookin some oil too.
Old May 11, 2008 | 05:24 PM
quicksilverado's Avatar
There does seem to be alot of oil on the plugs. If you are pushing oil threw the intake that can kill a motor just as fast as to little fuel.
Old May 11, 2008 | 05:29 PM
2005 Silverado's Avatar
SPAM HUNTER
If it was oil soaked they would be a little darker...Like number 7...they others IMO just have some carbon...so i dont think it was burning oil...again...IMO
Dustin
Old May 11, 2008 | 05:31 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
wow Chris this is a bummer...I hate to hear of **** like this, even from you...
Like what was mentioned already, 10lbs and 16* does not seem like enough to kill it, something else happened.
Old May 11, 2008 | 05:52 PM
thunder550's Avatar
High on diesel fumes
Yeah I've run the engine a lot harder than that before. I'm not sure what happened. I know the lean #7 is a common problem with the stock style intake manifolds though. I'm probably going to look into a Vic Jr now. I'm hoping that the cylinder wall and head are in decent shape. Hopefully it's as simple as putting in a new piston and rings and honing the cylinder.
I think the tune may have had something to do with it, but I'm not 100% sure. I think the new location of the wideband sensor (about 4" or so after the turbo) is causing it to get too hot. I was logging during that run, but right as I got into boost the wideband flatlined at 11.12:1 AFR and stayed there until I shut the engine down later. It's possible that since I had been messing with the tune that I had inadvertently leaned out some of the higher RPM cells. I thought that they would be inline with everything else, but without a good AFR reading it's hard to say. This was the second WBO2 sensor that I had burned up in 2 days. Part of me thinks that since it was heating up too much that it was giving me inaccurate AFR readings, which could have contributed to a lean condition without my knowledge. When I put this back together the WBO2 sensor is going back where it used to be, in the exhaust under the cab about 3 feet after the turbo. I never had any problems with it there.
Also, I was due for an oil change, and like I've said in the past, the oil is easier to change with the engine out This will also make the hydroboost conversion and thermostat swap a lot easier too
Anyway, she'll be back sooner than later hopefully, and back stronger than before I'm bummed out, but it's like I tell everyone....you gotta pay to play. I've done more paying than playing lately, but the tables have got to turn in my favor at some point.
