Longer Crank Bolt
#22
Originally Posted by mjhoward
Not to sound like an *** but once you use the heat meathod you will laugh at people that use a longer bolt. It is that much easier. $12 for a propane torch. After it takes you 30 secs to put grease on everything then 30-60 seconds to warm it, it will take you 5-10 seconds to pick it up and install it. I have done this at least 4 times in the last 4 months.
Not saying I wouldn't heat my pulley to put it on, I just used the longer bolt instead.
#23
Originally Posted by phasemaster1
This Might Be A Dumb Question But Will The Heat Method Work On The Asp Pulley Since Its Aluminum?
#24
This is probably going to fall on deaf ears here, but there have been quite a few people who have screwed up their crank threads using the bolt (stock or longer) to install the pulley. Many have even broke the bolt while doing it. The expense and effort to repair stripped crank threads is quite high.
#25
Propane isn't hot enought to melt aluminum I don't think. But nevertheless I would heat it if it was mine.
#26
#27
Originally Posted by BigBlockChev572
Would you take the chance on someone not aware of the melting points of aluminum and a torch on a crank pulley? You can't see aluminum overheat, It just melts, no indicators. Then you're out of luck.
#28
I work on Bombardier products and I use heat on all the aluminum differential and crank cases to ease installation of the bearings. Using a hand held propane torch is perfectly fine. I usually heat the parts to about 200* (using a handheld temp tester). I do the same for crank bearings on the Sea-doo's, heat the bearings on a bearing heating pad for about 15-20 min. and they slide right on the crank.
#29
I said I would heat it if it was mine. I'm fully aware of the affects of heating different metals. I was a welder/fabricator, heat treater, manual and CNC Machinist in my previous job. IMO - if you have the sense to do a cam swap you probably have the sense of how hot to heat a pulley for expansion and not to harm it.
But, some newbies may not have a welding background ( I have exepericence in this area too) and not be aware of aluminum and heat. Just trying to give other options.
#30
Not saying what you're saying isn't true
On the other hand, if you feel comfortable using the oxy/acet then go for it. I'd use it if I was out of propane.
