Longer Crank Bolt
Old Feb 15, 2006 | 12:41 AM
negativeswitches's Avatar
i need some how much are you asking for enought to make it work out? i assume 6" would be plenty
Old Feb 15, 2006 | 08:20 AM
KySilverado's Avatar
FWIW. McMaster Karr - Part # 91310A868 - It's a 5 pack of the correct length longer bolts. Oxide Stl Hex Head Cap Screw M16 Size, 120mm Length, 2mm Pitch
Old Feb 15, 2006 | 09:52 AM
Last Call's Avatar
TOTM: January 2007
I just bought 5 of them from McMaster Carr. Pay the shipping for the bolt and you can have it.
Old Feb 15, 2006 | 06:10 PM
phasemaster1's Avatar
Nice How Much You Want 33328 Zip Ft.lauderdale Fl
Old Feb 15, 2006 | 06:33 PM
JimS's Avatar
I need one. 61401. Let me know how to pay you. Paypal?
Old Feb 17, 2006 | 07:04 PM
BigBlockChev572's Avatar
For those who are curious, here's the bolt you use to get the pulley started. I didn't heat up the pulley. Just used the longer bolt with some spacers.
Old Feb 17, 2006 | 10:09 PM
TurboGibbs's Avatar
Not to sound like an *** but once you use the heat meathod you will laugh at people that use a longer bolt. It is that much easier. $12 for a propane torch. After it takes you 30 secs to put grease on everything then 30-60 seconds to warm it, it will take you 5-10 seconds to pick it up and install it. I have done this at least 4 times in the last 4 months.
Old Feb 17, 2006 | 11:07 PM
Not knocking the method.. I would be concerned about greasing and driving a SC. Unless you pin the balancer afterward.
Old Feb 18, 2006 | 05:19 AM
TurboGibbs's Avatar
You don't have to grease it. It just helps. My crank was pinned.
Old Feb 18, 2006 | 12:46 PM
This Might Be A Dumb Question But Will The Heat Method Work On The Asp Pulley Since Its Aluminum?
