Long Tubes+STS
Old Oct 16, 2005 | 05:50 PM
Injected1's Avatar
Default Long Tubes+STS
Anyone have any coment on this? Improvment in spool, power? Any loses?
Old Oct 16, 2005 | 06:10 PM
Jethro_3's Avatar
From what I understand the turbo already creates back pressure and the STS gets efficient enough flow from the stock manifolds to to a good job. Call STS and have them give you a number to someone local who installs for them.
Old Oct 16, 2005 | 06:40 PM
8ALTNG's Avatar
Not worth it. I have shorty headers and they flow just right.
Old Oct 16, 2005 | 08:55 PM
Injected1's Avatar
thanks for the input...maybe when I decide to go over 14psi and am starting to try and make big numbers I will get some then...
Old Oct 16, 2005 | 10:10 PM
8ALTNG's Avatar
I make 18psi and 515rwhp on a 89 degree day with a WEAK tune. Shortys will work
Old Oct 16, 2005 | 11:51 PM
bud8fan's Avatar
no need for lt's..i had shortys as well....the more heat you can get to the turbo the better it will run...the lt's will disapate the much needed heat quicker...the reason i say this is the harder i hit on that thing the better it got...3 runs back to back with no wait time...the 3rd run is the fasts
Old Oct 17, 2005 | 10:19 AM
Kerr's Avatar
friend has a set of long tubes on a camaro and the STS. He said that he wasted his money on the headers. I dont see how this cant help the turbo. I mean if the headers flow more, then the turbo should spool faster. however i dont have one so dont take anything i say to be correct.
Old Oct 17, 2005 | 10:52 AM
Stick with the stockers. The cast manifolds will retain heat which will aid in spoolup for the turbo.
twake_410
Apr 14, 2016 09:58 PM
bearden86
25
Nov 1, 2015 07:12 PM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
jscherbs
Sep 30, 2015 07:54 AM
old motorhead
Sep 29, 2015 08:22 PM
