long tubes and no tune?
Old Jan 12, 2007 | 12:55 AM
5-speedSierra's Avatar
Default long tubes and no tune?
safe to drive? not sure how these motors react to being catless. ive been told that there is a possibility that my A/F ratio could be unsafe. honestly i have no idea, so i figured id throw it out there and make sure its safe to drive regularly til i get a tune as soon as im ready with the new cam. thanks
Old Jan 12, 2007 | 01:47 AM
JT-bo's Avatar
I see you live in CA. what about CARB issues? If you don't have those problems then riding without a tune should be no problem. I did it for 3-4 months traveling about 80 miles a day. The motor will throw a code if the rear O2 sensors aren't tuned out though and you would benifit so much from a tune. I recommend you get one just for those 2 reasons but if you can't then you should be safe on the stock tune judging by the mods you have now.
What's a LOBACK muffler?
Old Jan 12, 2007 | 08:01 AM
Phantom's Avatar
11 Second Club
I drove with about the same mods as you for about 3 months before I got a tune...No biggie, just get used to seein your service engine light
Old Jan 12, 2007 | 10:51 AM
Mangled03gmc's Avatar
Baltimore Whore
I have been driving around with lt's and no cats for almost 2 years, the motor seems to be fine. All I have is a hyperjunk, from the looks and the sniffer it looks like it is running rich, mabye just do to not having the cats, but you should be fine...
Old Jan 12, 2007 | 10:59 AM
Phantom's Avatar
11 Second Club
I think thats your hyperjunk causing it to run lean...My truck ran real rich when I had mine with stock exhaust
Old Jan 12, 2007 | 11:13 AM
Baltimore Whore
Do ya mean rich, cause the pipes are black, the plugs looked ok last time I checked them. At any rate it is still alive.. , just need to get the 6.0 in there..
John
Old Jan 12, 2007 | 01:23 PM
Phantom's Avatar
11 Second Club
yeah i meant rich, sorry
Old Jan 12, 2007 | 05:37 PM
k cool, thanks.
loback is a custom muffler built in shop at RPM muffler in hayward, ca. its about a 4" diameter tube with a corkscrew type design run the whole length of the muffler and about a 1" diameter pipe through the center of the corkscrew. noise levels are created by the length of the muffler. i dont remember the smallest he makes i think its around 6", but it the longest is 30 or 36". i got the 16" and its pretty loud, but sounds awesome
Old Jan 12, 2007 | 08:05 PM
duwem's Avatar
Pacesetters with no cats...I am running rich when I hammer on it so no concerns. I run lean at idle and it idles like **** ocationally.
I had a wideband on it for about an hour to verify this
Old Jan 13, 2007 | 06:24 PM
007gmc's Avatar
i just put my lt's on my 07 with no tune and i don't have a engine light on. i don't under stand it. i expected it but it never came on.
