long tube question
Old Jan 7, 2013 | 01:49 PM
rooster clevice's Avatar
Registered User
Default long tube question
I have a00 z71 with a5.3 and was wondering which long tubes fit without cutting and welding preferably ones that bolt right up, I had a set of passengers but multiple people told me they wouldn't fit past the transfer case, I already have true duels
Old Jan 7, 2013 | 02:40 PM
2000chevysilverado's Avatar
Pacessetters with ory will work I had no problems with mine fitting. Depending how ur true duals are set up will be the other hard part you will have to do some welding or hadlve pipe bent up
Old Jan 7, 2013 | 02:44 PM
ivan_key's Avatar
Every set of pacesetters I have had they have fit perfect with out any problems, but sometimes there y pipes have fitment problems
Old Jan 7, 2013 | 05:24 PM
Registered User
I wouldn't want to run a y pipe, id really like to run an x pipe, id like to keep my cats, as of right now i only have cats and straight pipes
Old Jan 7, 2013 | 10:28 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You could easily add an X-pipe to this American Racing Headers system and also have high flow cats, and top shelf stainless headers. Fit and quality is second to none. PM me for special member pricing.
Old Jan 8, 2013 | 03:07 PM
Registered User
Pm sent and those do look awesome but considering I'm a lonely single marine, any suggestions on something a little less pricey?
Old Jan 8, 2013 | 04:45 PM
03sierraslt's Avatar
You are pretty much not going to be able to keep your factory cats with a set of LT's.
Old Jan 8, 2013 | 06:37 PM
Registered User
I mean I live in SC so that really isn't a problem we dint have any sort of inspection
Old Jan 8, 2013 | 07:17 PM
Ok, I was just letting you know. Do to the size of the factory cats and where LT's come out under the truck you dont have much to work with. Sounds like you can do as you please.
Old Jan 8, 2013 | 09:09 PM
Registered User
Yeah I'm just t trying to find the best bang for my buck option
AHelm3
Apr 8, 2016 07:51 AM
2500ZL1
Jan 25, 2016 06:30 AM
Martin4_8
Aug 13, 2015 07:31 PM
Castro45
24
Jul 31, 2015 07:13 PM
Suburban2500
Jul 13, 2015 09:57 AM
