whipple supercharger help
I don't think that will work. Unless that ss has l92 heads. Square port instead of cathedral! If the port are square like your port on your heads it will work. You might have to change some thing but it will bolt on. I have a 02 Chevy 5.3 and have a supercharger off of an 08 5.3. All I had to do was get an adaptor for the different throttle body and new plugs for the different fuel injectors
Another thing is make sure your pulley set up are the same from the 6.2 and 6.0. If they are your good a simple picture will tell you. Then look at throttle body's see if yours will bolt onto it. Then fuel injectors.
whippledstepside
09-17-2015 05:02 AM
scooter k
09-16-2015 10:32 PM
