long tube headers
Old May 26, 2006 | 10:43 PM
inmywhitez's Avatar
Default long tube headers
how much should it cost for someone to install my long tubes including welding them in? when i get these headers, should i keep my cats? run true duals? or will i still pick up just as much power with my current 3 inch dual exhaust.
Old May 26, 2006 | 10:57 PM
Z284thgen's Avatar
11 Second Club
man general wrenchs and sockets will get the job done and a sawzall to cut the old pipe off far enough back to get the LT's in there
as long as you have about 4-6 hours to do it on a weekend you can save your self about $150-200
Old May 26, 2006 | 11:16 PM
dry_kill's Avatar
U don't even need a sawzall to get your stock y-pipe out, just take off all the bolts on the flanges and drop the transmission crossmember, just have a jack under the tranny just to be safe, as far as cats, I wouldn't run em, sounds better without them but if u want to pass inspection then get a y-pipe made with cats on it, and also, a y-pipe exhaust system is plenty, true duals is overkill unless your pushin about 450hp
Old May 26, 2006 | 11:45 PM
PEDRO's Avatar
12 Second SUV Club
if ya go true duals x-pipe them, and i never removed my transmission crossmember but that was me and it took about 3 hours
Old May 27, 2006 | 09:56 AM
ZR1 DREAMING's Avatar
I did mine last weekend and they went in rather easy for doing it in a parking lot in a puddle.
Old May 27, 2006 | 01:56 PM
TarheelZ's Avatar
Originally Posted by inmywhitez
how much should it cost for someone to install my long tubes...
I paid $300 to have mine installed (headers and y-pipe). Then, like a dumbass, I was admiring the killer sound instead of watching where I was going and backed into the shop's water meter...busted the crap out if it and that cost me 6 bills!!!
Old May 27, 2006 | 04:06 PM
JT-bo's Avatar
I put mine on last night for free, by myself. I took about 6 or 7 hours. I recommend having some help though. I didnt drop the crossmember I just cut a little off the end of the y pipe so i could manuver it in there. Save the money and do it yourself.
Old May 27, 2006 | 06:46 PM
inmywhitez's Avatar
now, how much power is gained by long tubes? specify hp to the wheel or flywheel. Also, is it a huge difference?
Old May 27, 2006 | 08:09 PM
dry_kill's Avatar
Bout 20 to 25hp
Old May 28, 2006 | 10:50 AM
m7 rocket's Avatar
Do they help with lowering EGT's? or just add HP?
Dan Neumann
11
Aug 7, 2022 09:06 AM
lsxperformance
Apr 20, 2016 12:17 AM
2500ZL1
Jan 25, 2016 06:30 AM
Ken in AZ
Sep 17, 2015 07:08 AM
slowlsx
Aug 10, 2015 05:33 PM
