Limits
Old Nov 15, 2012 | 09:13 AM
Onetogofast's Avatar
Default Limits
The search gave me a very long list of cam questions but didn't find what I was looking for.
What cam lift is max for the factory push rods, valve springs and retainers? Which is crucial for replacement on cam swap in a sock 5.3 and if say the cam was around a 214/220 585 111.5 LSA? Thanks
Old Nov 15, 2012 | 09:54 AM
axekick's Avatar
If you change your cam you'll need to replace the springs. I think the Z06 cam is even too big for the stock 5.3 springs.
Old Nov 15, 2012 | 10:53 AM
nonnieselman's Avatar
theres a guy around here running a 218/224 .596/.598 113lsa cam on stock springs/PR's..
im waiting to see how long it last..
Old Nov 15, 2012 | 11:39 AM
AndysC3's Avatar
Lol, I bet it wont last long. I wouldnt spin the stock springs and pushrods past 5500. They are way too weak. Spend the extra 200-300 and get the cam and pushrods. Its better than having to replace the engine when you drop a valve
Old Nov 15, 2012 | 02:31 PM
So with a small cam, stock push rods and good single spring with stock retainers I will keep it at 5500 rpm redline. I only want a good choppy idle, it doesn't need to be fast or as big as I can go. If someone needs out run, I'll use the Denali LOL
Old Nov 15, 2012 | 02:35 PM
axekick's Avatar
With that setup you'll have no problems spinning up past 6000, unles you get a really small cam, but then why go to the effort.
Old Nov 15, 2012 | 03:59 PM
The effort is only 2-3 hours of my time and its easy, it needs tuned anyways and I'm doing it all for the big nasty idle sound is what I'm really going for. These trucks run good as they are
Old Nov 16, 2012 | 07:34 AM
axekick's Avatar
I don't really get doing a cam swap just for sound but the performance you gain makes it worth it if you get it tuned. You think it runs good now.
FlowmasterMufflers
Nov 24, 2015 01:00 PM
zblee
Nov 11, 2015 12:41 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
