lifters keep messing up
Old Dec 4, 2009 | 02:02 PM
denali-08's Avatar
Default lifters keep messing up
I just put some ls7 lifters AGAIN and they just last less than 2 weeks, I have been having this problem since i put the patriot dual springs the gold ones, I put them along the cam. what could be that its eating my lifters,
this is on a 6.2 l92 stock heads with 7.400 pushrods
Old Dec 4, 2009 | 06:21 PM
denali-08's Avatar
Old Dec 4, 2009 | 06:44 PM
02Reaper's Avatar
Got any pictures? Maybe you have the wrong size pushrods in there.
Old Dec 4, 2009 | 07:11 PM
KySilverado's Avatar
Keep messing up how? Too much pre-load. Poor lubrication, faulty cam or lifters.
Old Dec 4, 2009 | 07:13 PM
denali-08's Avatar
I dont know whats wrong, maybe pushrod lenght. whats the pre-load?
Old Dec 4, 2009 | 07:20 PM
Too lazy to explain pre-load.
http://cranecams.com/?show=techarticle&id=2
Old Dec 4, 2009 | 07:22 PM
May want to check the installed spring height. Could be coil bind, but then again you haven't specified exactly how the lifters are "messed up". Does this thing have VVT?
http://www.cpgnation.com/forum/comp-...tech-2047.html
Old Dec 4, 2009 | 08:18 PM
JoeyGC5's Avatar
Did you replace the valve seals also, or are you still using the stock spring/seat?
Old Dec 4, 2009 | 08:21 PM
stock48's Avatar
9 Second Truck Club
Never messed with a 6.2L but I know 7.400's are on the long side for a 6.0L with Ls7 lifters and non L92 heads. Seems the Ls7 lifter has a little bit higher plunger height than the 6.0L lifter.
Old Dec 4, 2009 | 08:49 PM
denali-08's Avatar
I change the seats for a shorter ones. this time I am gonna put some comp R lifters
