lifters keep messing up
Old Dec 4, 2009 | 08:54 PM
denali-08's Avatar
and does not have vvt
Old Dec 5, 2009 | 07:30 PM
JoeyGC5's Avatar
Why not run the Comp stock replacement lifters? I shift my L92 head/block 416 Vette at 6800 and in the current/past motor setups I've never had a problem with them.
Old Dec 5, 2009 | 07:50 PM
dlt76028's Avatar
Originally Posted by stock48
Never messed with a 6.2L but I know 7.400's are on the long side for a 6.0L with Ls7 lifters and non L92 heads. Seems the Ls7 lifter has a little bit higher plunger height than the 6.0L lifter.
would this account for lifter noise? i have a constant tick when cruising on the highway. i have a 6.0 with 62cc heads and ls7 lifters with 7.4 pushrods.
Old Dec 5, 2009 | 07:59 PM
hirdlej's Avatar
Old Dec 5, 2009 | 09:44 PM
dlt76028's Avatar
^^^ oh i forgot your an engine guru... but your smiley doesn't give me any help.
Old Dec 5, 2009 | 09:54 PM
GMCtrk's Avatar
I would pull a valve cover and use a pushrod checker to see if your pushrods are the proper length.
Old Dec 5, 2009 | 09:56 PM
dlt76028's Avatar
yea i know thats what i need to do. i'm jusy being lazy and was hoping someone else had the same setup so i could copy their pushrod length.lol
Old Dec 5, 2009 | 10:05 PM
GMCtrk's Avatar
hmm...you'd rather have a lifter failure?
Old Dec 5, 2009 | 10:11 PM
dlt76028's Avatar
eh, it runs good just makes a little noise. as far as i know its just aftermarket cam and springs. and infact now that i think about it, it might be the dual springs i've never had before.
Old Dec 5, 2009 | 10:35 PM
hirdlej's Avatar
You must measure your preload. YOU CANT COPY SOMEONE ELSES SETUP. PERIOD! never ever ever ever EVAARRRRR. I can't stress that enough.
As far as the OP goes, lifters never go bad. Only rollers wear out. Lifters can usually always be serviced by taking them apart and cleaning them. The only reason a lifter would collapse is either from poor fit (too much lifter bore clearance), not enough oil pressure (pinched o-ring or weak pump), or dirt stuck in the plunger not allowing it to travel.
