Lets play...Name that broken part
Old Oct 29, 2005 | 07:27 PM
  #181
parish8's Avatar
single digit dreamer
is that an adapter, i can't tell in the pic's.
if that is an adapter that will come off then you are probably ok but i still dont like diferent heads on there. if that is the actual crank then that motor is worthless and he lied to you.
Old Oct 29, 2005 | 07:45 PM
  #182
1SlowHoe's Avatar
Destroyer of Transmissions
Still not sure what you are trying to see. I put the flywheel back on and got as close as I could. Does this help you figure out whatever it is you're looking for. It's actually the flywheel off another 6.0.
Old Oct 29, 2005 | 07:47 PM
  #183
1SlowHoe's Avatar
Also, What are you trying to see? How would I know if the engine is a 99/00 by looking at the crank? What part would not bolt up to my truck?
Old Oct 29, 2005 | 07:49 PM
  #184
parish8's Avatar
your crank flange should be flush with that seal. it is sticking out right now. if that is the actual crank then you are screwed and that will not bolt up to a 4l60e
if that has an adapter on it then you are ok and it is a newer motor. here is a pic of the adapter.
Old Oct 29, 2005 | 07:51 PM
  #185
parish8's Avatar
the bigest reason i worry is those look like older 6.0 iron heads to me, the only motors they came on were the 99/00 with the crank that is too long. can you confirm those are aluminum heads? pull off a valve cover and take a pic.
Old Oct 29, 2005 | 07:56 PM
  #186
1SlowHoe's Avatar
They sure look and feel like iron to me. They guy who had the truck said they were his old 5.3 heads. I will get a pic in a minute. I have a 4L65E, but I don't guess that matters. Removing cover.....
Old Oct 29, 2005 | 08:01 PM
  #187
1SlowHoe's Avatar
I'm a bout to take the pic. Parish8 if you want to I can PM you my # or you can send me yours and we can talk.
  #188
those look like iron heads to me. stick a magnet to them if it sticks they are iron-if not you have aluminum.
Old Oct 29, 2005 | 08:04 PM
  #189
ktmrider's Avatar
Wow,this thread got long! I did not have the time to read it all but your motor failure sounds just like the one I had in the Dodge. The "knocking" noise is pieces of piston ring smacking around in the combustion chamber. Once they leave the area the noise goes away. Detonation and high EGT's due to poor tuning choices for me....
As for the motor I agree with Parish, that is an early iron head 6.0L motor. The casting number on the head ( lower right corner ) will tell all, no need to remove the valve cover. If it is a 5.3/4.8 head the number will be 862, aluminum 6.0L is 317, and i THINK the iron head is 843. That crank flange for the flexplate is poking way to far out to be the later model version.
Old Oct 29, 2005 | 08:13 PM
  #190
1SlowHoe's Avatar
Magnet sticks. Iron heads.
No casting # that I can see at all.
