left bank lean
Old Jul 25, 2007 | 11:31 AM
  #21
kirtondog23's Avatar
I checked the ohms and both the right and left side o2 sensors read at 05. Sould i get the same reading right to left. I am thinking that I should. I have cleared the code twice now and it does take a bit of driving for the code to trip again. I am wondering whether I might have a hard wire issue since my wiring guy has messed up a few things on the harness.
Any thoughts?
Anyone have pin outs for the left bank o2 sensor wiring?
Thanks
Old Jul 25, 2007 | 12:42 PM
  #22
NegraRCSB2X4auto's Avatar
Any thoughts?
Thanks
sounds very likely.
Old Jul 25, 2007 | 02:00 PM
  #23
Optimus1's Avatar
Originally Posted by shep28
I had that exact issue with my ls1 camaro. I cleaned my MAF, cleaned filter, tightened header bolts, checked for intake leaks, etc..... I ended up replacing the o2 sensors with corvette sensors- forgot what year.
They have a higher voltage than the stock sensors.
Have not had any issues after I installed them.
What? Do you mean they have a higher load (value)?
Also, running rich should cause your exhaust system to run cooler, due to excess fluid and incomplete burning. my .02
Old Jul 25, 2007 | 03:26 PM
  #24
I thought that the excess fuel getting burned in the cat would heat things up. Are you saying that an exhaust with to little fuel in it would run hotter?
I am now confused.
Pimpinpete
43
Dec 22, 2017 08:13 AM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
