it lasted 10 seconds.....
alright i will move it next to the top radiator hose and give it a shot. should i get a 160 thermo and set the fans for 170 if i can get a working thermo. thanks for the help
I set my fans at 176 and it holds just fine but it normally won't keep it at 170 unless it's winter. So basically trying to set em up for 170 would just mean your fans will never turn off.
Just buy a little auto zone on/off switch. And I would make sure that you didn't blow a fuse and the power wire from the battery has a fuse in it. That's what I did to be safe, may not be necessary tho
i finally got it working. i have the stock thermostat in place so i'm running that for now. i pulled the thermo probe and hit it with a heat gun and it started to run. i moved the probe closer to the radiator hose and the work juyst fine. i am going to run the toggle switch once i get one. thanks for all the help it was very useful
