Larger throttle body?
Old Nov 24, 2011 | 11:44 AM
SamuelsonMotorsports's Avatar
Default Larger throttle body?
Where can I find a larger throttle body for the LQ4 intake?
I have seen that professional products has one but im pretty leery of anything they sell.
I think the stock one is in the 65mm or so range? Is there a larger factory one around? Are all the LS1/LS6 throttle bodies the same?
Im trying to find a larger TB for my 02 2500HD 6.0 but everywhere I google or search, I only turn up the professional products TB. Please tell me someone else makes one...
Old Nov 24, 2011 | 11:50 AM
dmelvin's Avatar
It uses a 78mm just like every other NBS. You can look into a Nick Williams 92mm throttle body, but you're going to need a NNBS or a FAST intake to take advantage of it. The difference between the truck and the car throttle bodies is the butterfly opens the opposite way.
Old Nov 24, 2011 | 11:53 AM
neilownz's Avatar
BBK, but it's the basically the same as professional products.
Old Nov 24, 2011 | 01:08 PM
1slowz71's Avatar
55mm. Lmfao. Lol
Old Nov 24, 2011 | 06:40 PM
I found out that BBK makes a 85 and 80mm version-
Worth the cash? And can the truck nylon intake be ported enough to actually USE that throttle body? Whats the most anyone has made HP wise through the stock 78mm TB?
Old Nov 24, 2011 | 06:51 PM
dmelvin's Avatar
You'd be better off swapping to a NNBS/TBSS and going with the 90/92mm throttle body instead of trying to port the stock 78mm opening.
Old Nov 24, 2011 | 07:22 PM
youngbuck's Avatar
Yea tbss intake a tb is the way to go.
Old Nov 25, 2011 | 07:56 PM
Do they have that intake with a cable operated TB? I wouldn't mind doing the swap so long as everything bolts up and I can keep my cathedral port heads.
And of course, it needs to be able to support 600hp.
I know nothing of the tbss/nnbs yall speak about.
Old Nov 25, 2011 | 08:27 PM
neilownz's Avatar
Look at this intake swap thread
https://www.performancetrucks.net/fo...9-02-a-459296/
Old Nov 25, 2011 | 08:30 PM
bmd_CL's Avatar
trailblazer ss/new new body style...07+ intakes, they come stock with 90mm intake and throttle bodies if im not mistaken
