L92 vs LS3
Old Oct 7, 2010 | 03:05 PM
NightmareTBSS's Avatar
Default L92 vs LS3
These blocks both have 4.06 bore and same crank. What is the difference other than the cam size?
Old Oct 7, 2010 | 03:27 PM
Robert91RS's Avatar
LS3 has the lighter valves and I'm sure there is some different casting numbers on a few things but other than that they are the same. Compression might be different but I will have to check.
Old Oct 7, 2010 | 03:37 PM
Robert91RS's Avatar
Yeah, the L92 valve reliefs bring the CR down from 10.7 to 10.5
Old Oct 7, 2010 | 03:51 PM
JFOLM's Avatar
Intakes are different, no?
Old Oct 7, 2010 | 04:33 PM
yea...92 uses truck intake and LS3 uses the other
Old Oct 8, 2010 | 08:19 AM
Preston129's Avatar
LSX-L92 cylinder head
• L92 style rectangle port design
• 2.165" solid stem intake, and 1.590" solid stem exhaust valves
• 15° valve angle
• 260cc “as-cast” intake ports, 80cc “as-cast” exhaust ports
• 70cc “as-cast” combustion chambers
• Uses LS3 rocker arms/LS7 bolts
LSX-LS3 cylinder head
• 2.165" hollow stem intake and 1.590" solid stem exhaust valves
• 15° valve angle
Same block
Same pushrods and rockers
Different water pump and harmonic balancer
Different front timing cover
Old Oct 8, 2010 | 09:05 AM
• 15° valve angle
• 15° valve angle
Same block
Preshate that! Thats what I was looking for
Old Oct 8, 2010 | 09:58 AM
TXsilverado's Avatar
l92 comes with valve reliefs which lets you run a bigger cam.
Wolftrk99
Oct 2, 2015 08:17 AM
Mark_k
Oct 1, 2015 11:17 PM
redbird555
Sep 30, 2015 09:28 AM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 04:22 PM
