L92 Valve spring recommendation?
Old Feb 19, 2016 | 10:18 AM
kazfan30's Avatar
Default L92 Valve spring recommendation?
Hey guys, ive built plenty of Gen III stuff and cathedral port setups.. but this is my first square port Gen IV build.. I just had a custom cam spec'd and i wanted something reliable for many many miles. I ended up getting a 224/234 .598/.598 VVT cam... normally i would be ok with a .625 918 comp of similar beehive but since the valves are much heavier in this L92 head should i go with a big dual spring setup or will a beehive be plenty for what i need. Shift points will be setup at 6400.
Thanks
Old Feb 19, 2016 | 11:07 AM
Vortec350ss's Avatar
I would probably go with a dual to be safe, but I bet PSI or PAC 1518's would be fine.
Old Feb 19, 2016 | 02:55 PM
dirt track racer 81's Avatar
I had 20k+ miles on lunati .660 springs. Turned them 7500 with stock valves.
Blwn99x
Feb 6, 2016 08:27 PM
embs2001
Feb 4, 2016 01:33 PM
03sierraslt
Jan 30, 2016 03:57 AM
Jake75
Jan 24, 2016 01:18 PM
Mark Johnson
Jan 20, 2016 10:03 PM
