Gen 4 motor in gen 3 truck
Restricted
Besides the crank reluctor wheel, you have the knock sensors at the bottom of the block instead of in the valley cover, the cam sensor is positioned in the front timing cover..... I believe that's the only differences.... May just have to lengthen a few wires for a few sensors! Not too big of a deal
formerly Emmerich 5.3 (2013-11-30)
Katech has one for $60 that's a 2 in 1 harness. Here's a good thread that tells you everything. How to Install an LS2 in an LS1 car
Edit: after looking into it it seems i have to change the crank position sensor to the gray one and the cam sprocket to a 1x design not 4x that comes with the gen 4 block. Correct?
