L92 heads in 2000 silverado 1500
Old Mar 22, 2012 | 06:16 PM
gmchrisz71's Avatar
Default L92 heads in 2000 silverado 1500
Im doing a motor swap from a 4.8L to a 6.0L and want to put on L92 cylinder heads. I read an article online and it said i have to use the L76 intake with the L92 heads and was wondering if anybody has done this and what exhaust headers you used and what cam.
Old Mar 22, 2012 | 07:30 PM
batboy's Avatar
11 Second Club
The L92 heads have rectangular intake ports and must be matched with an intake manifold like the L76. You will need to use the L92/LS3 head gaskets and off-set L92/LS3 intake rockers, plus injectors and rails to match the intake.
Old Mar 22, 2012 | 08:34 PM
andrew383's Avatar
traveling mod
Also the headers will stay the same,only thing that changes fitment wise is the intake mani
Old Mar 22, 2012 | 09:09 PM
skeet's Avatar
you can use the rectangular port truck intake being dbc youll need to make a bracket for the cable and such
Old Mar 22, 2012 | 09:52 PM
Atomic's Avatar
I have a gauge for that
You can use an L76, L92, or LS3 intake.
Old Mar 23, 2012 | 09:23 AM
gmchrisz71's Avatar
okay thanks for the input guys so looking at the intakes is there any pros or cons on the different ones or are they all the same.
Old Mar 23, 2012 | 01:31 PM
batboy's Avatar
11 Second Club
I don't have personal experience, but the guys I know that have done this on GTOs claim the L76 manifold flows the best of the stock choices.
Old Mar 24, 2012 | 08:04 PM
CHILLLLLL's Avatar
formerly Stroked-DSM (11/24/2010)
Car manifolds will give you better numbers. They do flow better. BUT you need to change water pump, accessory pulley location, and shave the alternator bracket. I just went with a stock L92 truck mani for my heads cam 408 until edelbrock releases a rectangular port pro flow. I was thinking about the Holley hi ram but I believe it's too tall to fit under the stock hood. I could be wrong I haven't actually measured
Old Mar 31, 2012 | 11:22 AM
gmchrisz71's Avatar
Alright thanks
how would you go about measuring to see if you could fit the Holley hi ram
Old Apr 2, 2012 | 02:43 AM
CHILLLLLL's Avatar
From top to bottom the Holley is 11 3/4 inches. My stock L92 truck intake is 9 3/4. I would make a cardboard box the height of the Holley and stick in on the valley cover, close the hood, and see if it crushes the box. If it does, you know it won't fit under your stock hood
