L92 cam swap
hi there guys.. i need the best cam i can install on my 09 denali, im ordering
ARH 1 3/4 with cats soon... then installin the cam... i have 2 questions..
1) is it ok to install a cam with stock headers?
2) which one to go with... *stock heads* i may get cylinder heads.. later on after im done with everything... stage 2 from livernois.. anyways..
218,229 LSA 117.5 OR 224,227 LSA 114 *low lift*
any other cams u guys recomend..
regards
regards
Why would you ever think of getting rid of VVT? Its a hotrodders dream!!!!
Comp Cams has a cam for your engine that made a 70hp gain without any torque losses. It was on a stock(with headers) 6.2L L92 with cam, springs, and phaser limiter kit. You can not do that without VVT!!
Article: http://www.gmhightechperformance.com/tech/0903gmhtp_l92_comp_cams_vvt_cam_kit_install/index.html
edit:COMP Cams XFI™ SPR Camshaft, 275PHR14
Here are two of COMP's VVT cams:
p/n 156-402-13 has an operating range of 1800-6900 rpm, 218/232-degrees of duration at .050, .563/.575-inch lift and a 114LSA. Comp says it has a noticeable idle, and is extremely strong in the upper rpm.
Meanwhile p/n 156-403-13 is designed for all-out power in a stock cube application with CNC-ported or aftermarket heads with 222/236-degrees of duration, .566/.578-inch lift and 114LSA. If these splits seem drastic, that is just the nature of L92 or LS3 heads and actually has nothing to do with the VVT.
