L92 cam swap
Old Dec 6, 2009 | 01:39 PM
supercharged680's Avatar
Question L92 cam swap
hi there guys.. i need the best cam i can install on my 09 denali, im ordering
ARH 1 3/4 with cats soon... then installin the cam... i have 2 questions..
1) is it ok to install a cam with stock headers?
2) which one to go with... *stock heads* i may get cylinder heads.. later on after im done with everything... stage 2 from livernois.. anyways..
218,229 LSA 117.5 OR 224,227 LSA 114 *low lift*
any other cams u guys recomend..
regards
Old Dec 6, 2009 | 06:29 PM
03_SS_22's Avatar
yes its ok. you just wont get the peak performance out of it.
you have the 6.2? if you do go with the 1-7/8 with cats.
what are your goals?
Old Dec 6, 2009 | 11:33 PM
yeah 6.2... just headers + cam... thats all
Old Dec 7, 2009 | 06:09 AM
Tootall's Avatar
you'll need the cam phaser kit if you're planning on keeping VVT . . .
Old Dec 7, 2009 | 02:10 PM
is it better to keep it? what if i dont want to.... is it good as well
Old Dec 7, 2009 | 04:06 PM
Tootall's Avatar
there are far more cams to choose from if you get rid of it vs keeping it. There's no cam reluctor in the rear
Old Dec 7, 2009 | 08:12 PM
SweetS10V8's Avatar
Why would you ever think of getting rid of VVT? Its a hotrodders dream!!!!
Comp Cams has a cam for your engine that made a 70hp gain without any torque losses. It was on a stock(with headers) 6.2L L92 with cam, springs, and phaser limiter kit. You can not do that without VVT!!
Article: http://www.gmhightechperformance.com/tech/0903gmhtp_l92_comp_cams_vvt_cam_kit_install/index.html
Old Dec 7, 2009 | 10:19 PM
Tootall's Avatar
what's the specs or part numbers for the 2 cams that were tested ?
edit:COMP Cams XFI™ SPR Camshaft, 275PHR14
Here are two of COMP's VVT cams:
p/n 156-402-13 has an operating range of 1800-6900 rpm, 218/232-degrees of duration at .050, .563/.575-inch lift and a 114LSA. Comp says it has a noticeable idle, and is extremely strong in the upper rpm.
Meanwhile p/n 156-403-13 is designed for all-out power in a stock cube application with CNC-ported or aftermarket heads with 222/236-degrees of duration, .566/.578-inch lift and 114LSA. If these splits seem drastic, that is just the nature of L92 or LS3 heads and actually has nothing to do with the VVT.
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Jul 29, 2015 01:28 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
Deceptarado
Jul 8, 2015 05:24 PM
