L33 Z06 Cam and Z06 pushrods??
Old May 17, 2009 | 08:43 PM
gjohnson's Avatar
Default L33 Z06 Cam and Z06 pushrods??
Hey guys, I recently picked up a L33 adn T56 for my budget swap for my 97 Nissan 240sx. I'm trying to learn as much as possible about the LSX engines, but I've ran accross a really good deal. I know that the L33 has the 799 heads, which are basicly LS6 heads and I've allready picked up my LS1 intake. I'm currently entertaining an offer for 03 Z06 Cam, Springs and Pushrods for $150. I've try to search all night and I keep reading that the stock pushrods can handle this cam, but that it is best to upgrade to the 7.45s. Well, considering my budget (wife and 3 kids) I'm trying to keep my spending down. Can I run the Z06 pushrods as a upgrade to my stock L33 pushrods? How do they compare to the 7.45's?? Thanks
Old May 17, 2009 | 09:38 PM
neilownz's Avatar
Use a pushrod checker. I assume you arent going to be doing any machining on the heads... Wouldnt 7.4 be the correct size?
Old May 18, 2009 | 09:58 PM
gjohnson's Avatar
Sorry, man I don't know what a pushrod checker is. This is the first time I've ever dealt with a LS engine. Only other engines I've worked on have been dual over head cam Nissans, which don't have pushrods.
Old May 18, 2009 | 11:06 PM
neilownz's Avatar
Should try to find a LS engine teardown/buildup book or ebook. They probably sell somethin decent on ebay if you look hard enough.
I think there might be some info if you search a little on here or ls1tech.com or ls1howto.com.
Old May 18, 2009 | 11:16 PM
SincalT/A's Avatar
If you are going to use stock pushrods use the l33's.The z06 pushrods are shorter to make up for the longer valve stems on the ls6 heads.
Old May 20, 2009 | 03:33 AM
454SuperSport's Avatar
the pushrods are exactly the same, throw in the zo6 cam/springs and let it eat.
Old May 20, 2009 | 03:36 AM
the longer valve stems make up for the smaller base circle on the ls6 cam, pushrods are the same
Old May 20, 2009 | 06:17 PM
SincalT/A's Avatar
Your right long day for me I new better jus forgot.
Camshaft Base circles
Ls1=.7756
01 ls6=.7598
02-04 ls6=.7480
Old May 21, 2009 | 10:15 AM
gjohnson's Avatar
Well, sounds good guys. I'm going to stick with the L33 stock pushrods.
Hey, can anyone let me know the easiest way to swap out a cam on these LSX engines. My engine is on a engine stand right now.
5.3Okasai
Mar 9, 2022 01:07 PM
Jake99
Aug 8, 2015 07:56 AM
lxcoupe
Jul 30, 2015 02:42 PM
jaypowe11520
Jul 29, 2015 07:59 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
