105amp vs 145amp for performance ?
Old May 20, 2009 | 03:25 PM
Dark Halo's Avatar
Default 105amp vs 145amp for performance ?
Just wondering if you think it would make a differance in performance in swaping alternators? The only reason I ask is, I swaped my 105 to a 145 but dont really have any reason to be running the 145 other than I had it and it is new vs my 5 yr old 105. My scsb is turnning into more of a track truck than street truck. No A/C, heat, ect, but it does have 05 truck fans.
Old May 20, 2009 | 03:41 PM
SUPERCHARGE's Avatar
Hmm... someone correct me if I'm wrong but... I believe getting a higher AMP alternator causes more resistance on an engine and will LOWER your HP. A higher amp alternator would be good for people who may consume lots of power, like multiple off-road lights, big sound system, etc. But all in all, if you need performance, a smaller Amped alternator should be better, causing less resistance on the engine.
Old May 20, 2009 | 03:43 PM
Dark Halo's Avatar
well see thats what I would think but I thought I would check before I pull it off.
Old May 20, 2009 | 04:03 PM
marlboroman71818's Avatar
not really. The alternator has a regulator mounted on it. That regulator determines how much draw (amperage) is being demanded from the vehicles electrical systems (lights, radios, ect). If more of a demand is sensed, only then will the power to the magnetic feilds increase making it harder to turn the alternator and producing more electricity.
Old May 20, 2009 | 04:15 PM
Dark Halo's Avatar
so should I keep the 145 or put the 105 back on?
Old May 20, 2009 | 04:16 PM
nonnieselman's Avatar
I dont think your goin to see a gain/loss from a Alternator, it depends on how much of a demand your electrical system draws as to how much of a load the engine sees.
Old May 20, 2009 | 04:39 PM
like nonnieselman says keep the 145. If you had more than 105 amperage draw your alternator would overheat and either burn up or if it has a heat sensor it will stop charging. Having the higher amperage rated alternator can only help you.
Old May 20, 2009 | 05:11 PM
blueflamed03's Avatar
more juice is always better when you have the added current draw, if ever, keep the 145, but you won't see HP gains.
Old May 20, 2009 | 05:16 PM
budhayes3's Avatar
PT's Slowest Truck
It won't make **** of a diff, keep the 145
Old May 20, 2009 | 10:36 PM
slow.8's Avatar
not to hijack, but would a 145 keep my voltage from dipping at idle, i have an asp crank pulley, and the headlights get really dim if im idling.
