L33 or LQ4
Old 07-28-2015, 11:52 AM
Registered User
jaypowe11520's Avatar
Default L33 or LQ4
I have a 05 silverado that's basically stock. I want to take the L33 and punch it out to basically be an ls1 with a cam. I'm also debating on getting a LQ4 and throwing in a cam and make about the same horsepower, then dropping it in the truck. What are y'alls thoughts on this? Any other suggestions? Thanks guys
Old 07-28-2015, 12:16 PM
chadjcompton's Avatar
I've always heard its way easier to make a lot more horse power with a 6 liter. I'm starting to see that now that i have a lq9. I used to have a lm7. Granted i know the l33 is way sweeter than the lm7, but i've read so many times if you're looking for 400+ rwhp you are better off going to the lq4 or lq9. You'll make 400 way easier with less money and have a stronger engine.
Old 07-28-2015, 04:42 PM
01silvy's Avatar
There is no replacement for displacement! I went with a L33, moderate cam, healthy head work, bored 0.020 over, and 10.8:1 compression. It made right at 300/300 on the dyno in 2nd gear. This is with a stock z71 4l65e and 3:73 gears with 32" all terrain tires. I was a little disappointed because i hoped for about 325-340 hp but at the end of the day its not a dyno or track queen, it gets daily driven and runs awesome on the street. With that being said, you can take a 6.0 with a good rebuild, healthy cam and head work and make pretty good power.
Old 07-28-2015, 05:14 PM
Registered User
I thought it would be really cool to basically have an LS1 running in my truck but the more I think about it I kind of want to do a 6.0 swap plus if I want to make a stupid amount of power later on I can always stroke it for now I'm thinking maybe a LQ4 with flat tops a relatively healthy streetable cam and then maybe some heads down the road after I beef up the trans. Do y'all have any better ideas? I want to stay away from boost
Old 07-28-2015, 05:29 PM
Registered User
I've heard 400 rwhp is kind of hard to do with a few mods like I want to do. I've been growing on the idea of a 6.0 with flat tops and a cam. Them maybe later on build it to the dagum sky
Old 07-29-2015, 06:51 AM
Why don't you just do a LQ9? Its the high output 6.0 with flat top pistons. Thats what my truck has. Its a 2007 silverado classic vortec max. I got volant cool air intake, longtube headers, and a really awesome tune and it rolls out! I'm probably putting down 320+-? I'm going to do a custom cam and stall. I feel like once its cam'd and re tuned she'll be putting down close if not right at 400 rwhp
Old 07-29-2015, 07:02 AM
Registered User
I'm getting the first thing I can get honestly. I don't want to wait around for an lq9 when I'm rebuilding it anyway, might as put flat tops in it anyway.
Old 07-29-2015, 07:39 PM
GREENSIERRA's Avatar
being someone that has had a H/C/I L33 and then a H/C/I LQ4, defanitly go LQ4.
the added torque the 6L produced was amazing over the L33.
Old 07-29-2015, 07:47 PM
Registered User
Man I really appreciate that. I've almost deffinitly decided on the LQ4 with some mild work done. Maybe a 224r cam or something along those lines, and then heads down the road. I deffinitly want to go with a little higher torque numbers and a good amount of horses under the hood
Old 07-29-2015, 07:52 PM
Vortec350ss's Avatar
The 6.0 will be a lot cheaper in the end. You don't need to rebuild it if it's in decent shape. Change your head selection to hit your target compression. Changing Pistons will require a lot of work and it will get much more expensive real fast.
Quick Reply: L33 or LQ4
