Kenne Bell Question
Alright, I'm reading up on my suprecharger installs to decide which one to buy. I noticed with the Magnacharger, and the Whipple you have to install new larger injectors, which would make sensa. On every Kenne Bell install I've read about, there's no injector replacement. How do they do that, and make the boost like the other blowers. I'm up on all the threads about roots versus screw blowers, so let's not bother with that. Thanks.
The whipple uses two aux. injectors that push fuel through the intake manifold... The Kenne Bell's setup is the same as the Radix... 8 brand new 42lb injectors (I think thats the size) The larger injector replacements on the whipple are done seperately by people. The 8 larger injectors do not come in the whipple kit.
Ok....so the Kenne Bell setup DOES have larger injectors! That sounds more like it! All the installs I've read about, no one say anything about replacing the injectors. I figured they had to get extra fuel in there SOME way! Man...I'm tempted to with the Kenne Bell setup, but everything I hear about their customer service is BAD, BAD, BAD! I just don't feel comfortable with the Whipple piggy back setup. The Magnacharger is a real good setup, but I've been around Alcohol Dragster racing a long time, and I've seen the benefits of the screw blower! Thanks
You're right, The KB are 42# injectors. Do not go for the 2 aux injectors. Upgrade to 42# if you using a whipple setup. The KB is alright if you can get custom tuning.
How was your experience with KB's customer srevice? I've been lead to believe that's the stumbling block.
carid
Sep 10, 2015 09:07 AM
