Kenne Bell Question
Old Nov 15, 2004 | 08:19 AM
wkdivr's Avatar
Question Kenne Bell Question
Alright, I'm reading up on my suprecharger installs to decide which one to buy. I noticed with the Magnacharger, and the Whipple you have to install new larger injectors, which would make sensa. On every Kenne Bell install I've read about, there's no injector replacement. How do they do that, and make the boost like the other blowers. I'm up on all the threads about roots versus screw blowers, so let's not bother with that. Thanks.
Old Nov 15, 2004 | 09:03 AM
greentahoe's Avatar
Im not sure exactly but if there is no replacement injectors than additional fuel will be supplied through an FMU or aux injectors like tha whipple it is based on.
Old Nov 15, 2004 | 03:45 PM
01Sierra's Avatar
The whipple uses two aux. injectors that push fuel through the intake manifold... The Kenne Bell's setup is the same as the Radix... 8 brand new 42lb injectors (I think thats the size) The larger injector replacements on the whipple are done seperately by people. The 8 larger injectors do not come in the whipple kit.
Old Nov 15, 2004 | 03:59 PM
wkdivr's Avatar
Cool
Ok....so the Kenne Bell setup DOES have larger injectors! That sounds more like it! All the installs I've read about, no one say anything about replacing the injectors. I figured they had to get extra fuel in there SOME way! Man...I'm tempted to with the Kenne Bell setup, but everything I hear about their customer service is BAD, BAD, BAD! I just don't feel comfortable with the Whipple piggy back setup. The Magnacharger is a real good setup, but I've been around Alcohol Dragster racing a long time, and I've seen the benefits of the screw blower! Thanks
Old Nov 15, 2004 | 05:19 PM
wkdivr's Avatar
Angry
Alright....Now I really feel like a dumbass! I just looked on their site, and it explains about the injectors in the description. Shoulda looked there first!!
Old Nov 15, 2004 | 08:04 PM
You're right, The KB are 42# injectors. Do not go for the 2 aux injectors. Upgrade to 42# if you using a whipple setup. The KB is alright if you can get custom tuning.
Old Nov 15, 2004 | 08:46 PM
01Sierra's Avatar
Definately need a custom tune w/ a KB setup...Superchargedchevy04 went from a 15.0 to a14.5 with a tune alone...
Old Nov 16, 2004 | 05:53 AM
wkdivr's Avatar
Exclamation
How was your experience with KB's customer srevice? I've been lead to believe that's the stumbling block.
Old Nov 16, 2004 | 10:00 PM
It was actually OK. They were good at programming PCM's and if you can take the vehicle to them for the tuning even better. Unfortunately I live in Toronto so that was not possible. Looking back I still would have bought the KB but do the tuning locally because every vehicle has some variation that requires a certain amount of custom tuning to optimize especially using a dyno. The customer service line is always busy and that was frustrating.
FlyingLow
Nov 24, 2015 10:05 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
