Katech Oil Pressure
Old Jun 11, 2006 | 09:38 AM
RGMEPP's Avatar
Pump is out. My o-ring was the correct cross sectional diameter( not the blue one for f & y bodies). And, I was right it was green, not red. kind of a medium green in color. new o-ring, purchased at Sinclair Buick/GMC is also green. A dark, grass like color. I used part # 12563963 to get the ring. The man behind the counter informed me that there was a new part # for this item. The new number is 12584922.
My guess is the o-ring has been changed, or improved. Otherwise, why the number change ???
Old Jun 12, 2006 | 02:25 PM
RGMEPP's Avatar
New ring, same ol' pressure. 22-23 idle, 35@2500, 40@3500. Lot a work for no result. When the old 6.0 was pulled, stock oil sending unit was broken. Replaced through the local parts house. I think a test with a mechanical guage is in order, and/or a new sender from the dealer. Any thoughts folks ??
Anyone got the GM number for the sender ??
Old Jun 12, 2006 | 02:34 PM
ranwalk's Avatar
Need to know some specs on the bearing clearances. Some engine are built with looser tolerances which would result in lower oil pressure.
I also believe, not 100 percrnet sure on this, that a ported oil pump will flow more, but show lower oil pressure as well. I would keep an eye on it, see if it is consistant. You still have good pressure. Rule of thumb is 10 psi for every 1000 rpm.
Old Jun 12, 2006 | 02:38 PM
RGMEPP's Avatar
I think watching the f'er close, and a check with a mech. guage will be on order for now.
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
