Katech Oil Pressure
Old Jun 6, 2006 | 06:37 PM
RGMEPP's Avatar
Default Katech Oil Pressure
So, the stroker runs great, but I'm curious. what kind of psi should I be getting from a ported katech pump. Can't remember what the stocker was pulling, but seems lower. 23-25 idle, & 30-35 highway.
Old Jun 6, 2006 | 08:32 PM
Zick's Avatar
That is pretty low. My stock oil pump is pushing 50psi cold@idle, 40psi hot@idle, and about 65-75 @WOT.
Old Jun 6, 2006 | 08:53 PM
RoninsDenali's Avatar
Thats pretty much what my stocker pump is giving me... Even after 83,000mi...
Old Jun 6, 2006 | 09:03 PM
I get the same on stock oil pump with 280,000 miles on it.
Old Jun 6, 2006 | 09:40 PM
RGMEPP's Avatar
Zick's numbers seem to be about what I got out of my stocker, if the memories not going to . Would have thought I'd get better than that of a 83 or 280,000 mi stocker, with a high perf. pump.
Could this be the old "O-RING" that many have trouble with ?? Post I've read say blue is a , and red o-rings are best. Mine was green, any thoughts ???
Old Jun 6, 2006 | 09:59 PM
Zick's Avatar
O-ring would be my first culprit I would check. Heard way too many horror story about that stupid little rubber ring.
Btw, I used the red O-ring with my new engine. Not sure about the green
Old Jun 6, 2006 | 10:09 PM
RGMEPP's Avatar
Who sells the red ring ???
Old Jun 6, 2006 | 11:18 PM
Zick's Avatar
Dealership is where I got mine.
Old Jun 7, 2006 | 09:35 PM
RGMEPP's Avatar
IF YOU COULD DESIGN A P/U TUBE & PUMP COMBO, THAT ELIMINATED THE BASTARD O-RING, A RICH MAN YOU WOULD BE !
Old Jun 7, 2006 | 10:11 PM
budhayes3's Avatar
PT's Slowest Truck
I'd be re-checking the o-ring also, those numbers sound low to me. My stocker runs right where the other guys mentioned (a tad above 40 psi at idle, and over 65-75 at WOT...sometimes it hits 80 psi when it's cold)
