K&N intake, will fit on my 06
Old Apr 30, 2006 | 04:43 PM
Default K&N intake, will fit on my 06
Someone just gave me a K&N intake for free but I looked on a site and it said that part# was for 99-04 not 05-06 that they were a diffrent #. What are the diffrences if anyone knows and can I make it work. The part# is 57-3021-1
Old Apr 30, 2006 | 04:54 PM
erronisme's Avatar
I think the hoods are higher...the heat shield wont quite reach the hood...
Other than that, I THINK they are the same
Old Apr 30, 2006 | 05:57 PM
05-06 also have the electric fans, which makes for more room in front of the motor in the engine bay. It should work, it's just the tubing was designed around a more cramped engine bay with the 99+
Old Apr 30, 2006 | 07:52 PM
NO F-BDY BS's Avatar
Im curious myself, I have a gen II that was on my 04', It looks like it will fit even better on my 06' as the fan shroud will not be in the way, however, I do want it to seal against the hood so it will pull air from the fender/below the engine.
Can anyone confirm/deny if it will seal against the hood?
Old May 4, 2006 | 07:03 PM
jvtex's Avatar
I have an O5' and i had to cut and bend the heat shield because the radiator and Efans seem to be a bit larger than Pre 05's. I also notice that there isn't a heat shield indent in my Under Hood foam, so perhaps it doesn't go all the way.
However i did notice the Swoooosh when i matted the throttle!!
joel
Old May 4, 2006 | 11:24 PM
joel
I decided to sell mine, and just get an 06' Airaid setup, its in the classifieds if anyones interested.
The_W
Oct 28, 2015 09:00 PM
jroctpb
Aug 11, 2015 03:52 PM
Aboss
Aug 11, 2015 09:05 AM
Denali08
Aug 9, 2015 04:34 PM
MWRitter
Jul 27, 2015 09:41 AM
