just ordered cam package-lifter tray question?
Old Oct 2, 2008 | 05:00 AM
wkdivr's Avatar
I'd leave the trays alone. If doing the cam swap, it's relatively easy. To change the lifter trays, you have to remove the heads. Then....you're getting into more work. On these engines, you can change cams without even removing the lifters, just rotate the cam a few times after undoing the timing chain, should stay up in the trays. When re-assembling you have to give the lifters a solid push down to get them to go back down on the cam lobes.
Old Oct 2, 2008 | 06:34 AM
nemmarick's Avatar
like i said im also doin springs,push roods, retainers and the cam..... so the heads can stay on for all this?
Old Oct 2, 2008 | 07:28 AM
wkdivr's Avatar
Yes. No need to remove the heads for the springs, just get a tool to pump the cylinder with air, and a tool remove the springs. The Crane tool is the best, but pricey.
Old Oct 2, 2008 | 10:28 AM
whitegmc2003's Avatar
if you dont have an air compressor you can buy some rope and fill the cylinder with rope to keep the valve from dropping
Old Oct 2, 2008 | 12:06 PM
circusboy's Avatar
you might want to get something to hold the lifter up, either the magnets or dawl rod method. The last thing you want is a lifter falling out then you have a lot more work on your hands, lol
Old Oct 2, 2008 | 12:33 PM
wkdivr's Avatar
Mine had 60,000 miles on it when I did my GT2-3, and I had to snap the lifters back down on the cam when I put the pushrods back in.
Old Oct 5, 2008 | 02:10 AM
When I did my cam swap I just spun the cam both ways a couple times. Then I slide the wood dowel in and continued spinnin the cam until they were all the way in. When theyre in your lifters wont fall.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
USMCvet0311
Jul 29, 2015 01:28 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
EscaTruck
Jul 20, 2015 11:42 AM
