Just changed my fuel pump, what a PITA!
Just thought I would share my crappy experience. I went in to change the fuel level sender and decided to do the whole pump/sender assembly while I had the tank down. I highly recommend doing this w/ the tank near empty!! I siphoned out about 10 gallons and ended up storing it in my cooler for a couple hours
The only other problem was the metal ring that holds the pump snug against the tank. It was a bitch to get it on w/ the new pump. I don't know why but I spent a good half hour just trying to get that damn thing down far enough to rotate so that it locked the pump down. Hopefully this new pump/level sender will last another 75K miles or so.
yeah, definetely not the funnest things to do...but way easier with a lift!!! oh yeah, and good call on replacing the whole assembly. I dont quite understand why you had such trouble with the lock ring......never had problems getting them on, just off....hmmm....
I here ya on the PITA. I ended up droping my tank three times to get it right. Once to put new in, once to put old back in so I could send the new in for warranty and the third time I finnaly have a working gas gauge
Originally Posted by toneloc12345
Next time, just take the bed off..... Only 8 bolts and unplug a couple of harnesses by the bumper. That's the way I do it at work.
Hey Bigred your sig is great, that's the point I'm at w/ the T/A. Don't really want to spend $2K for a set of heads to pick up 35 RWHP!
Originally Posted by Red99TA
I probably would have done it this way except I can't...this was on a Tahoe.
Originally Posted by bigredexpress99
werd........hmm. makes me think......
makes ya think what bro??? hey big red where you work out of??? you work for gm too right? what do you do?
