Just changed my fuel pump, what a PITA!
Old Oct 8, 2006 | 09:05 PM
Red99TA's Avatar
Default Just changed my fuel pump, what a PITA!
Just thought I would share my crappy experience. I went in to change the fuel level sender and decided to do the whole pump/sender assembly while I had the tank down. I highly recommend doing this w/ the tank near empty!! I siphoned out about 10 gallons and ended up storing it in my cooler for a couple hours The only other problem was the metal ring that holds the pump snug against the tank. It was a bitch to get it on w/ the new pump. I don't know why but I spent a good half hour just trying to get that damn thing down far enough to rotate so that it locked the pump down. Hopefully this new pump/level sender will last another 75K miles or so.
Old Oct 8, 2006 | 11:11 PM
bigredexpress99's Avatar
yeah, definetely not the funnest things to do...but way easier with a lift!!! oh yeah, and good call on replacing the whole assembly. I dont quite understand why you had such trouble with the lock ring......never had problems getting them on, just off....hmmm....
Old Oct 9, 2006 | 12:30 AM
usmcchevy's Avatar
I here ya on the PITA. I ended up droping my tank three times to get it right. Once to put new in, once to put old back in so I could send the new in for warranty and the third time I finnaly have a working gas gauge
Old Oct 9, 2006 | 05:58 AM
toneloc12345's Avatar
Next time, just take the bed off..... Only 8 bolts and unplug a couple of harnesses by the bumper. That's the way I do it at work.
Old Oct 9, 2006 | 06:07 AM
Red99TA's Avatar
I probably would have done it this way except I can't...this was on a Tahoe.
Hey Bigred your sig is great, that's the point I'm at w/ the T/A. Don't really want to spend $2K for a set of heads to pick up 35 RWHP!
Old Oct 9, 2006 | 10:56 AM
yeah, kinda where I'm at as well.....
Old Oct 9, 2006 | 11:23 AM
CHEVRACER83's Avatar
Ive Rarely Had A Lock Ring Problem.... Unless The Big O Ring Fuel Tank Seal Was Binding A Little.....
Old Oct 9, 2006 | 11:45 AM
Gran Patron's Avatar
True that!! If you got a truck its a wayyyyyyyyyy easier that way. That's the process I went about using
Old Oct 9, 2006 | 06:13 PM
werd........hmm. makes me think......
Old Oct 9, 2006 | 06:18 PM
makes ya think what bro??? hey big red where you work out of??? you work for gm too right? what do you do?
