junk yard build...tell me if this will work
Old Jul 14, 2009 | 08:02 PM
bulldogSS's Avatar
Default junk yard build...tell me if this will work
4.8/5.3 block
5.3 rods
4.8 flat pistons
5.3 heads w/.40 gaskets
6.0 cam
using the flat top pistons and thinner head gaskets to up comp. a little. and using the 6.0 cam because it mildly better than the 5.3 cam.
hoping to get 20 more hp/tq than a stock 5.3. what cha think???
Old Jul 14, 2009 | 08:07 PM
006rcsb's Avatar
6.0 cam is a waste of time, if you have it out go with something bigger. sounds like a cool build other than that, kinda like an iron L33.
Old Jul 14, 2009 | 09:29 PM
silveradokidd_4518's Avatar
im with him on the 6.0 cam
pick up a Z06
Old Jul 14, 2009 | 10:13 PM
Cooder5.3's Avatar
Good Luck on the build. Keep us up to date.
Old Jul 15, 2009 | 05:49 AM
Tootall's Avatar
pick up a $125 regrind on ebay if you're going to make it that cheap
get a 212/218 low lift if you're just wanting 20hp more
Old Jul 15, 2009 | 11:17 AM
bulldogSS's Avatar
never thought about getting regrind. ill run it by my friend who the motor is for. we are just trying to get the most motor possible out of the parts we already have on hand. we have a complete 4.8, a complete 5.3 and a few parts i upgraded on my 6.0. thanks for all the advice guys keep it coming. thanks
Old Jul 15, 2009 | 03:03 PM
dug's Avatar
dug
Banned
you can find some used cam pretty cheap on ls1tech.
Old Jul 15, 2009 | 07:29 PM
PathfinderJr's Avatar
regrind's aren't worth it in my opinion. I've heard/seen too many lobes go sour cause of them being regrinds. I'd just stick a baby cam in there, ie <= 212/218 low lift, and call it a day.
Old Jul 15, 2009 | 11:01 PM
dug's Avatar
dug
Banned
https://ls1tech.com/forums/lsx-parts...p-cam-new.html
check out this cam.
Old Jul 16, 2009 | 02:01 AM
RockKrusher's Avatar
Well hot damn I was just about to post about doing the same exact thing using a couple of junkyard motors, however one question remains, how much compression will be gained by using the flat top pistons? (What is the volume of the dish in the 5.3 pistons?) (sorry if I am Hi-Jacking)
