Itnake Manifold questions
Hey does anyone out there know if the 4.8/5.3/6.0/Z06 5.7 intake manifolds are interchangable. I have a 5.3 Silvy and need to upgrade the intake manifold. Ready for supercharger's forced induction.
The manifolds are physically interchangeable, but you will have to modify the accessories to run the car intake. The TB and the idler pulley would share the same real estate if you didn't!
Do a search in this section...you'll find all kinds of info!
Ok with that said, should i then when looking for my manifold if see one that fits the stock 6.0 aplication i should be fine with the fit to my 5.3?? Thanks for your help
So basically i need to find an intake manifold for a 01 6.0l silvy and that should be a direct fit to my 5.3 01 silvy.
You don't have a manifold?
Oh yeah and how do you like those bosch plat 4's in the silvy 2001si3rr
no not a swap i just needed to know because every intake mani that ive found have been LS1 LQ9's and so forth basically everything except my 5.3l go figure. Iwant to supercharge in the future and need to upgrade that aspect of it first
