Itnake Manifold questions
Old Mar 30, 2004 | 12:33 PM
01Blackerado's Avatar
Default Intake Manifold questions
Hey does anyone out there know if the 4.8/5.3/6.0/Z06 5.7 intake manifolds are interchangable. I have a 5.3 Silvy and need to upgrade the intake manifold. Ready for supercharger's forced induction.
Old Mar 30, 2004 | 01:17 PM
Scream's Avatar
MOOBIES Moderator
The manifolds are physically interchangeable, but you will have to modify the accessories to run the car intake. The TB and the idler pulley would share the same real estate if you didn't!
Do a search in this section...you'll find all kinds of info!
Old Mar 30, 2004 | 03:40 PM
Cool
Ok with that said, should i then when looking for my manifold if see one that fits the stock 6.0 aplication i should be fine with the fit to my 5.3?? Thanks for your help
Old Mar 30, 2004 | 03:58 PM
2001si3rr@'s Avatar
From my understanding the 4.8, 5.3, and 6.0 share the same intake manifold. The only thing different should be the EGR blocked off on the newer 02' and up models.
Old Mar 30, 2004 | 04:02 PM
So basically i need to find an intake manifold for a 01 6.0l silvy and that should be a direct fit to my 5.3 01 silvy.
Old Mar 30, 2004 | 04:04 PM
Oh yeah and how do you like those bosch plat 4's in the silvy 2001si3rr
Old Mar 30, 2004 | 04:09 PM
2001si3rr@'s Avatar
The newer manifold will fit your truck.
You don't have a manifold?
Old Mar 30, 2004 | 04:11 PM
2001si3rr@'s Avatar
Screw those Bosch plugs, they are crap. Electric current can not ground through 4 different places at the same time. I should have thought more about it before buying them. I have some NGK TR-55's on the way now, they should be alot better.
Old Mar 30, 2004 | 04:12 PM
grooves12's Avatar
I think you need to be a little more clear. Are you looking to swap to the 6.0L manifold as a performance upgrade?? If so... you are wasting your time. They are the SAME EXACT manifold.
Old Mar 30, 2004 | 04:18 PM
no not a swap i just needed to know because every intake mani that ive found have been LS1 LQ9's and so forth basically everything except my 5.3l go figure. Iwant to supercharge in the future and need to upgrade that aspect of it first
